jeep yj backfiring when shuting off - JeepForum.com
post #1 of 7 Old 04-05-2013, 11:00 AM Thread Starter
Burtman88
1987 YJ Wrangler
So i ve been having a problem with my 87 2.5 yj backfiring after i shut it off. It seems to just backfire not sputter. I replaced all the vacuum lines, spark plugs,plug wires,fuel filter,new muffler no cat co verter, and also replaced exaust manifold.
So after most of this my idle went from 1500 to around a 1000 or 1200 which is still very high. It idles at 900 when cold but warms up to the others rpms i just said. So before i had back fire everyonces in awhile. I just replaced my 02 sensor now it back fires everytime i turn off the yj which is annoying and scares ppl around me. Its been 3000 miles since the exaust manifold swap and fix. It does sound like i have a exaust manifokd leak again which would suck since i paid someone else to do it. Do i need to reset ecm for the new 02 sensor all i did was disconnect battery for 20 mins. Ill get a video of it soon running and how it sounds.
87 YJ 2.5 inch lift 1 inch shackle BF AT 33-1250-r15
00 WJ
09 WK Hemi, 2.5 inch Rc lift, Super chips,Gibson 3 inch catback, rough country spacers, Voolant Cai,lockpik, Falken Wild peak At 265/70R-18
Burtman88 is offline
post #2 of 7 Old 04-05-2013, 11:10 AM
Jax89Jeeper
Have you checked your timing? Your idle is too high and needs adjusted which can be caused with timing too advanced, this can also create a backfire situation.
Jax89Jeeper is offline
post #3 of 7 Old 04-05-2013, 11:32 AM Thread Starter
Burtman88
1987 YJ Wrangler
Where would i take it to get timing done i have never done this before. Also what i be looking at for price of changing timing.
00 WJ
post #4 of 7 Old 04-05-2013, 01:01 PM
Jax89Jeeper
Any shop can handle this... The price is hard to guess. It can vary quite a bit. Just make sure the shop will not perform any work until you have been quoted and okayed the price.
post #5 of 7 Old 04-05-2013, 04:15 PM
Xpress
Pick up a timing gun and a service manual and check it yourself, don't pay someone else to do the work. These things are incredibly easy to work on.
By the way you need to disconnect the positive battery terminal and ground it out on the NEGATIVE terminal for 30 seconds to drain the caps inside of the computer to reset it.
All about that unibody life.
Xpress is offline
post #6 of 7 Old 04-05-2013, 05:11 PM Thread Starter
Burtman88
1987 YJ Wrangler
ohh ok thanks, i didn't know i had to reset the comp. I ll try to do the timing my self then i don't feel like paying fro labor anymore than i already have. Also i think its also a vacuum leak i am having with the high idle also. I just went out and hit a huge mud hole to fast it filled my whole engine bay with slimy mud accept for the intake luckily. Now since that happened my idle is down to around 700 to 1000 which is hilarious since the mud did a temp seal somewhere. The only place i can guess thats leaking is on top of the valve cover gaskets. I can lift them up with out any effort like they are to wide to seal to valve cover and both are 3 months old. Its the breather in the back and the pcv in front grommets may be my issue. So iam wondering if this could cause it or are the grommets suppose to be very loose.
00 WJ
post #7 of 7 Old 04-05-2013, 05:20 PM Thread Starter
Burtman88
1987 YJ Wrangler
Heres the engine bay with to much mud
00 WJ
