jeep yj axle tube seal fix - JeepForum.com
post #1 of 5 Old 03-30-2006, 08:10 PM Thread Starter
cage013
this is for a yj front d30 axle when going to the tj axle shafts its hard to find seals so
as the seal issue goes on and on
i have found a solution
i measured the inside diameter of the pass side axle tube next to the carrier.
you have to kind of figure out where the machined surface on the axle shaft will be when its in the axle housing and measure the tube id at that point
then measure the o.d. of the axle tube at the seal surface
then call a local bearing and drives shop
examples bearings unlimited. bearings and drives etc in your area give them the dimensions and they can find you the correct seal . these places usually sell hydraulics pumps and parts like that they usually sell gears chains drives etc
i dont have the number seal that i used but the i.d has to be just about perfect. the od of the seal can be sanded down with a stationary sander to fit
all cost about 8$ and works great
cage013 is offline
post #2 of 5 Old 03-31-2006, 01:19 AM
92 Green YJ
92 Green YJ's Avatar
umm, whats the issue? they make a seal that fits perfect. its made by chicago rawhide, i have the part number if you want. got it at kragen for 2 bucks
92 YJ. High Output 4.0L
Rubicon Express 4" Lift Kit, 2" Body Lift,15x8" AR 767s, 35x12.50 Xterrains, Home Made Snorkel, Sanden OBA, Home made rocker gaurds. 8.8 Rear with Discs, 4.10s F&R, ARB rear, Detroit EZ Locker front, WarnM8000 with Viking Synthetic Line, Beadlocks, Tons of Mods
My
Score: 682RRv1.0 with a BOA of 13.47
I'm now doing custom bumpers and lift installs in So-cal
92 Green YJ is offline
post #3 of 5 Old 03-31-2006, 10:52 AM
letsroll
please post the part number/.
letsroll is offline
post #4 of 5 Old 03-31-2006, 11:12 PM Thread Starter
cage013
well 92 green yj i didnt have an issue but many folks did/do
i have the c/r seal in my housing now i just didnt write down the part number
i was just trying to let people know that there are options to make this work without getting the expensive 100$ fancy outer seals
if you know what part number fits in there no problem then please take it upon yourself to help others out and post the part number
i am sure that many will find it helpful and save them a ton of time searching and a bunch of money
thanks
andy
cage013 is offline
post #5 of 5 Old 04-01-2006, 02:03 AM
92 Green YJ
I have posted this before but whatever. the chicago rawhide part number for the necessary seal for converting to a one piece inner shaft is 11800. like i said, i got it at Kragen for like 2 bucks
My
Seal driver for front axle seal, disconnect side sequel YJ Wrangler Technical Forum 24 01-24-2010 06:05 PM
D44 axle tube seal? NotmyJK TJ Wrangler Technical Forum 1 12-22-2009 06:51 AM
95 jeep keeps blowing passenger side axle seal Flurry184 YJ Wrangler Technical Forum 17 12-05-2008 08:46 PM
axle tube dust seal madmikey TJ Wrangler Technical Forum 4 07-31-2006 08:20 PM
dana 30 axle tube seal upgrade bailey TJ Wrangler Technical Forum 4 11-01-2004 09:29 AM
