jeep yj 4wd popping - JeepForum.com
post #1 of 8 Old 05-27-2014, 09:15 AM Thread Starter
bmiller3392
jeep yj 4wd popping
I have a 1991 jeep wrangler that the 4wheel drive has been popping when I drive straight in 4wd and when I turn it will occasionally pop completely out of 4wd the forks got stuck this winter and I got them unstuck but ever since I fixed that this has been happening
so if anyone has any ideas I would appreciate the help
bmiller3392 is offline
post #2 of 8 Old 05-29-2014, 11:29 PM Thread Starter
bmiller3392
Bump
post #3 of 8 Old 06-17-2014, 06:15 PM Thread Starter
bmiller3392
Bump*
post #4 of 8 Old 06-17-2014, 06:45 PM
jay-h
It seems like either the vacuum system is erratic or the fork actuator is bad.
First try running with straight vacuum to the 4wd side and see if it still pops in and out. If not, then the problem is in the vacuum switch or the hoses to it. Truthfully you can leave that vacuum engaged permanently (mine has been left engaged for about the past 90K miles).
If the forks are dropping out, you can rebuild the actuator, replace with a manual lock, or simply physically lock the fork in place.
My toys
'89 Wrangler YJ
'47 CJ2-A
wife's toys
97 Grand Cherokee (ZJ)
87 MB 560SL roadster
jay-h is offline
post #5 of 8 Old 06-17-2014, 09:16 PM
JGRIM
Sounds like the vacuum actuator to me also. I recently had the same issue. I replaced mine with a brand new "defective" actuator which only prolonged the agony until I figured out what was going on. I ultimately chose to physically lock the shift fork into place. If you choose to go this route, do not tow it unless you have installed a TJ shift mode selector in the transfer case. Jerry
JGRIM is offline
post #6 of 8 Old 06-18-2014, 10:08 AM
jay-h
Actually I would disagree with that warning. As long as your TC is in neutral it should be just the same (at the front axle) as 2wd.
My toys
'89 Wrangler YJ
'47 CJ2-A
wife's toys
jay-h is offline
post #7 of 8 Old 06-18-2014, 05:29 PM
ErikJordan
Pimp Hand
ErikJordan's Avatar
Popping at the differential or the transfer case?
___________________________________________
What is all of this talk of Savvily designed products?
ErikJordan is offline
post #8 of 8 Old 06-18-2014, 08:03 PM
JGRIM
Not true. When you shift a YJ transfer case into neutral, the front and rear drive shafts remain locked together. If the front axle shift fork has also been locked into the engaged position, you will be towing it as if it is in 4wd. Jerry
JGRIM is offline
