Jeep YJ 4.2L Wiring question. - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > YJ Wrangler Technical Forum > Jeep YJ 4.2L Wiring question.
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineThe Boss is away but Erin is here to STAY with a F.Y.S. SaFS: 2007-2013 Jeep Wrangler "HALO" Angel Eye Kit
Unread 05-22-2015, 04:16 PM   #1
BigJ367
Hello all, I am in the process of putting in a complete wiring harness in my Jeep since my old one decided to give up the ghost.
My question lies in the picture below. Where does this batch of wires go and what are they for? It seems to plug into something behind the glove box. I have no idea what this is for and I don't want to go cutting and screwing things up. Thanks!
BigJ367 is online now   Reply With Quote Quick reply to this message
Unread 05-22-2015, 05:42 PM   #2
dancytron
That bunch cables is what goes to the Computer/ECU. If you've done the Nutter bypass, you can just chop it off, follow the wires and get rid of them. If not, you need to keep them.
dancytron is offline   Reply With Quote Quick reply to this message
Unread 05-22-2015, 07:41 PM   #3
BigJ367
I personally have not done the nutter bypass but I took the ECU out when I installed my HEI distributer. So I could take it out either way right?
Unread 05-22-2015, 11:54 PM   #4
dancytron
Yeah, take it out. The easiest way is to reach under the dash and cut it with a cable cutter or heavy pair of scissors and push it through the hole. Then take it apart and follow the wires and take them out.
Unread 05-23-2015, 09:40 AM   #5
jimbos76cj
Only a hand full of wires need to be re-used with a harness install. You must keep the wiper switch to wiper motor harness. If you are using an HEI every thing in the engine compartment can come out. I even got rid of my Starter relay.
88 YJ 35's 8.8 rear, family style roll bar, ax-15 external slave conversion, Custom double D fab dash 4" of lift taurus fan, Head light wiring upgrade, MSD 6al, JB conversions SYE, 258 with RV cam, Long tube headers, Borla exhaust. 1"mm, Auto meter gauges.
jimbos76cj is offline   Reply With Quote Quick reply to this message
Unread 05-23-2015, 01:02 PM   #6
BigJ367
Ok great. Thanks for the help! I found out my problem is in my steering column. There is a short in the ignition wiring up in there. My connectors that plug into the top of the column are fused together. :astonished: I need to take off the column housing but I have no idea how. It might even require me taking out the entire column. I think I know how to do that, its just the column housing that I don't know how to take apart. Any ideas?
Unread 05-26-2015, 06:50 AM   #7
BigJ367
So I think I have found my problem. It looks like the ignition switch (the one on the top of the column) is bad. Below is the switch itself and the connector(s) that plug into it. Do any of you guys know what pins do what? I think 2 on the far right are for actually starting the vehicle but what about the rest? I am going to replace the whole switch but I would hate it if I burnt it up again due to not truly fixing the problem.
Unread 05-26-2015, 01:59 PM   #8
jimbos76cj
What brand harness are you using? Most have that plug already installed.
Unread 05-27-2015, 06:36 AM   #9
Que89YJ
Those wires are so cooked I cant tell whats what. You need to definitely figure out what shorted before you reassemble. Look at the color of the wires on the back to figure out the circuits. Download the factory manual here:
http://www.jeepforum.com/forum/f12/1...start-1414928/
Post 11
Que89YJ is offline   Reply With Quote Quick reply to this message
Unread 05-27-2015, 02:37 PM   #10
BigJ367
I'm taking out the entire harness. It was the factory one. Replacing it with a complete painless kit.
Post 11
Yeah, I have a new switch on order. Hopefully it will be in by the end of the week. New switch, new harness hopefully means I fixed the problem but I want to be sure before I burn another one up... Thanks for the link! I'll look it up and see what plug does what.
Unread Yesterday, 09:41 AM   #11
jimbos76cj
Complete painless kit will come set up for that ignition switch..
Unread Yesterday, 04:37 PM   #12
BigJ367
Yeah, I've got it all set up to plug in. Hoping that with a complete kit and new switch it will clear up the short. I couldn't find anything else wrong on the column.
Unread Today, 08:01 AM   #13
BigJ367
So I've run into something else. I have the switch installed but when I went to test it with the key it doesn't always want to return to "run".
For example, I'll turn the key to "start" or crank it but it doesn't always want to return to "run". It's like it's sticky. I've cleaned out all the grease and reapplied oil throughout the arm and lever system. I'm pretty sure I have the spring set correctly. Is there another spring or something else I have missed? Attached is a pic of how it's set up now. It is in the "locked" position.
Unread Today, 08:39 AM   #14
BigJ367
Here is the pic.
