jeep yj 4.0 passenger oil leak - JeepForum.com
post #1 of 4 Old 12-20-2011, 06:19 PM Thread Starter
jeepyj13
yjers i need some assistance on this issue. recently my 93 yj has been leaking oil pretty badly on the pass. side of engine. ok i looked under it and the only indication to my reasons is that the starter is basically drenched in oil. it has a spot of oil under the starter on tyhe ground too so i assume my oil sending unit is going out cause theres oil all over it too. i see no leaking around the valve cover pan so i marked that out. is this a common problem on these 4.0L. im mechanically incline but havent worked on vehicles for sometime. if this description i gave you all is correct, is it easy to replace? this is my DD too. thanks
"Its a Jeeps World, other 4x4s just get stuck in it."
jeepyj13 is offline
post #2 of 4 Old 12-20-2011, 06:57 PM
PA_YJ19
almost everyones valve cover leaks at some point, go get one they r like 5 bucs. I think theres 8 bolts if i remember correctly and clean the surface very well before putting it back on as well as torque it down correctly. I would go that route and clean up the whole area so then u can drive around a little and see if that was it or u have a leak sumwhere else in that vicinity.
PA_YJ19 is offline
post #3 of 4 Old 12-21-2011, 06:58 AM
Berniebikes
Probably in order that you will need to check
valve cover
oil sending unit
dipstick tube (little o ring where it inserts to the block)
or if you are like me with a mechanical fuel pump removed and a blockoff plate, check that.
Berniebikes is offline
post #4 of 4 Old 01-20-2012, 11:25 AM Thread Starter
jeepyj13
got it fixed! it was the oil sending unit. this is a great site and thanks yjers
jeepyj13 is offline
leak in passenger floor footballgoody YJ Wrangler Technical Forum 2 09-10-2011 03:24 PM
Passenger side Oil Leak tbauer TJ Wrangler Technical Forum 5 07-07-2011 07:33 AM
passenger door leak 07rescuerubi JK Wrangler Technical Forum 3 03-12-2009 05:06 PM
Leak in the passenger side baseballcaz TJ Wrangler Technical Forum 2 12-02-2008 05:20 PM
Leak in passenger foot well?!? chuck148 YJ Wrangler Technical Forum 17 12-18-2002 11:40 AM
