Jeep won't turn over - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > YJ Wrangler Technical Forum > Jeep won't turn over
KrawlOff-Road.com Sale EventFS: Jeep Fog Light LED Bulbs! Several Brightness Options! *STOP UNWANTED LIGHT BAR NOISE* with Pandemic LED Light Ba
Unread 11-24-2009, 09:02 PM   #1
Fenix85182
Hey guys,
I've got an 89 Wrangler with the 4.2 with 193K on it. I was cruising around today when I went through a massive puddle, as I generally would. I drove another 6 miles, pulled into a spot in a parking lot when the Jeep stalled out. I let it sit for a while, which usually does the trick, but to no avail. My girlfriend and I were able to push it out of the lot to roll it down a steep hill, but I wasn't able to pop start it (which I have plenty of practice with). My thought was that it needed gas, so I put 2 gallons in from a gas can, still nothing. I called AAA and got it towed home. Four hours later, still nothing. It cranks and cranks but won't start up. Any ideas?
2005 Jeep Wrangler TJ Sport
2009 Honda Accord EX
2008 Honda CBR600RR Graffiti Edition
Fenix85182 is offline   Reply With Quote Quick reply to this message
Unread 11-24-2009, 09:56 PM   #2
plyguitar45
Did you get your distributor wet?
That would explain it not working even if you have tried roll starting it.
I did something similar like that offroading a while ago.
Anyway, I popped the cap off the distributor and soaked it in wd40.
Fixed my problem.
- New Jeep :D-
3.7L '04 Manual Liberty KJ, all stock
-SOLD MY JEEP :(-
2.5L Red '91 YJ w/ 2.5" RC lift, 2" BL, 31" MT Baja Claws, Superwinch LP8500, RH4x4 Front Bumper, JKS Quick Disco's, Rampage Nerf Bars
plyguitar45 is offline   Reply With Quote Quick reply to this message
Unread 11-24-2009, 10:06 PM   #3
BigDumbBear
1978 CJ7
Sounds like an issue with water in a connector or a blown fuse from a short.
If it ain't broke, fix it till it is!
Efficiency is the lazy man's way of getting something done.
I have not failed, just succeded in finding many ways that did not work.
Originally Posted by stpeteTJ View Post
Haha, that's not a safety. That's a danger-y.
BigDumbBear is offline   Reply With Quote Quick reply to this message
Unread 11-24-2009, 10:07 PM   #4
H3RTCH
Live Free or Die.
H3RTCH's Avatar
Check to see if the engine is getting fuel. I'm not familiar with carbs, so I'm not sure as to how to do it.
Brandon
2004 Jeep WJ Grand Cherokee Overland - My DD
1988 Jeep MJ Comanche 4.0L - Dad's
1999 Jeep WJ Grand Cherokee Limited 4.0L - Mom's
H3RTCH is offline   Reply With Quote Quick reply to this message
Unread 11-25-2009, 12:03 AM   #5
Apollo12227
I would definatly say pull your distributor cap off and make sure its bone dry in there... even a little moisture can effect your startup... i've sean people with cracked caps have a humid day mess with their ignition system.
Start with inspection of the cap, then go from there, but I would put money on that dist. cap. Fuel "shouldn't" have been effected by the puddle... That doesnt mean that the puddle and fuel problem could be unreleated but coincidental, so check what can directly be effected by the puddle before you move further...
Hate to mention this... but check your air filter for water... I hightly doubt any water got to it what-so-ever but better safe than sorry.
Apollo12227 is offline   Reply With Quote Quick reply to this message
Unread 11-25-2009, 06:45 AM   #6
vector6
when its cranking does the tach move at all? or stay at the bottom...
vector6 is offline   Reply With Quote Quick reply to this message
