jeep wont start - Page 8 - JeepForum.com
post #106 of 113 Old 02-09-2013, 02:39 PM
fourbtgait
1930 MK Patriot
Originally Posted by JCashen
Yeah. I just picked up the bigger diode. Going to soulder it here shortly.
Although if it is running with key off and I yank the connect of the little red wire to the 12v it turns off. When I check the wire it only has power when key is on.
I might extend the wires into the cab and put them on a switch.
The red wire that switches the box on?
It should have power at crank and run
fourbtgait is offline
post #107 of 113 Old 02-09-2013, 03:08 PM
fourbtgait
1930 MK Patriot
Mines up and running.
I noticed the msd changed my timing some so had to reset that.
Have vacuum gauge hooked to manifold vacuum now to run engine diagnostics
post #108 of 113 Old 02-09-2013, 03:26 PM Thread Starter
JCashen
I still need to get one of those. From what I read they're an invaluable tool.
Does your jeep sound different after the msd? I swear mine sounds louder.
JCashen is offline
post #109 of 113 Old 02-09-2013, 03:43 PM
fourbtgait
1930 MK Patriot
Lol, it might sound a little throatier or stronger.
I just posted in the CJ forum a question about my vacumm readings. All seemed good but one reading seems off a bit.
Its taken me 35 years to finally use a vacuum gauge and I am amazed at what it can tell you.
post #110 of 113 Old 02-09-2013, 05:31 PM Thread Starter
JCashen
I won't be able to pick one up until next week, but I'm going to start reading up on how to use a vacuum gauge. Seems like the simplest tool that provides the most benefit.
I finally got the bigger diode soldered in. Turning off and on like a champion. Now to just wait for the new carb.
Do you think it would be hard to wire the red power for the MSD into the cab and put a switch on it? What would be needed and would it be an effective kill switch?
JCashen is offline
post #111 of 113 Old 02-09-2013, 05:33 PM
fourbtgait
1930 MK Patriot
If it runs/turns off now, why?
You can put a switch on the white wire to ground as a kill switch. Msd tells how. Just put the switch under the dash.
post #112 of 113 Old 02-09-2013, 05:54 PM Thread Starter
JCashen
I didn't know you could use the white wire as a kill switch, sounds a lot easier.
What did you end up gaping your plugs too?
JCashen is offline
post #113 of 113 Old 02-09-2013, 06:26 PM
fourbtgait
1930 MK Patriot
0.45
