jeep wont start - Page 7 - JeepForum.com
post #91 of 113 Old 02-08-2013, 11:40 PM Thread Starter
JCashen
Oh can we wrap the diode in like electrical tape? Or leave it bare?
JCashen is offline
post #92 of 113 Old 02-08-2013, 11:54 PM Thread Starter
JCashen
The main reason I ask about the timing is that when looking at it with a timing light it will sit at 8btdc but seems like it jumps to around 0tdc randomly.
JCashen is offline
post #93 of 113 Old 02-09-2013, 04:29 AM
Que89YJ
You need to wrap the diode in tape to stop it from shorting out. It stops backfeed from the power. It had no effect on timing.
Fault codes:
Mean Max pics of everything:
No Start:
Que89YJ is offline
post #94 of 113 Old 02-09-2013, 08:22 AM Thread Starter
JCashen
Sorry I didn't mean to make it seem like I thought the 2 were connected.
It is good to know I need to tape it.
And
Thank you four and que!
JCashen is offline
post #95 of 113 Old 02-09-2013, 09:24 AM
fourbtgait
1930 MK Patriot
If it is jumping around, say 0-8, it would be from surging of the engine.
Did you disconnect and plug the vacumm advance line when you timed it?
fourbtgait is offline
post #96 of 113 Old 02-09-2013, 10:09 AM Thread Starter
JCashen
Vacuum line was plugged. Should I be worried about it if I can drive it around? I lugged it in high gear up hill and low gear high rev. Couldn't hear any detonation and I can tell a difference in the way it drives now and did.
Edit: even with the diode I get run on after driving it. Though just turning it on and then off is fine. I wrapped it in tape. Would a 3a400v diode help?
Fourbtgait how is your jeep running with your 6a?
JCashen is offline
post #97 of 113 Old 02-09-2013, 10:24 AM
Que89YJ
With the advanced plugged and timing jumping around it sounds like the timing chain is stretched. You can drive it but you need to figure out why.
Fault codes:
No Start:
Que89YJ is offline
post #98 of 113 Old 02-09-2013, 11:18 AM
fourbtgait
1930 MK Patriot
I havent finished yet. Just now leaving junkyard. I found a 93 family bar to put in my cj.
Did you solder diode in correct orientation?
I have a part # at home for one recommended by jeephammer. I noticed it is larger.
post #99 of 113 Old 02-09-2013, 11:20 AM
fourbtgait
1930 MK Patriot
When time surges, is the engine itself surging in rpm, not holding steady?
post #100 of 113 Old 02-09-2013, 11:41 AM Thread Starter
JCashen
I don't have a working tach yet so I can't tell engine rpm. From ear it sounds like it the engine does surge.
JCashen is offline
post #101 of 113 Old 02-09-2013, 12:01 PM
fourbtgait
1930 MK Patriot
More than likely, if the engine rpm's are surging at idle, the emulsion tubes may be clogged a bit.
The carb is a carter bbd?
If so, google the bbd surging at idle. It is a common problem, easy fix.
post #102 of 113 Old 02-09-2013, 12:04 PM
fourbtgait
1930 MK Patriot
The diode that was recommended to me is a radio shack #276-1144
Did you install new plug wires? 8 or 8.5 mm?
post #103 of 113 Old 02-09-2013, 12:16 PM Thread Starter
JCashen
I had just installed new plug wires. They're 8mm motor craft ones jeep hammer had in his team rush post.
JCashen is offline
post #104 of 113 Old 02-09-2013, 12:40 PM
fourbtgait
1930 MK Patriot
Ok good.
Soldering the diode sucks.
post #105 of 113 Old 02-09-2013, 01:32 PM Thread Starter
JCashen
Ok good.
Yeah. I just picked up the bigger diode. Going to soulder it here shortly.
Although if it is running with key off and I yank the connect of the little red wire to the 12v it turns off. When I check the wire it only has power when key is on.
I might extend the wires into the cab and put them on a switch.
JCashen is offline
