jeep wont start - Page 6 - JeepForum.com
post #76 of 113 Old 02-08-2013, 05:08 PM Thread Starter
JCashen
New coil is on. It can hear it start to catch but it just doesn't. I have to go to work but this weekend it should be up and running.
I'm thinking the issue now is timing. I'll find tdc again and verify correct rotor placement.
Unless you guys have any other suggests it might be.
I out starter fluid down the carb and it wanted it bad but couldn't get it.
JCashen is offline
post #77 of 113 Old 02-08-2013, 05:16 PM
fourbtgait
1930 MK Patriot
So now you are getting spark to plugs?
If so it is timing.
A slight twist of dizzy should get it close to starting, then time it.
fourbtgait is offline
post #78 of 113 Old 02-08-2013, 05:19 PM
fourbtgait
1930 MK Patriot
What are your plugs gapped at?
New plugs?
post #79 of 113 Old 02-08-2013, 06:54 PM Thread Starter
JCashen
Original plugs gapped to stock length. I think .035.
Yes spark to plugs.
JCashen is offline
post #80 of 113 Old 02-08-2013, 07:46 PM Thread Starter
JCashen
I can increase gap, I wasn't going to change plugs until I get the new carb on.
JCashen is offline
post #81 of 113 Old 02-08-2013, 09:02 PM
fourbtgait
1930 MK Patriot
You can increase your plug gap to 0.40 or possibly even 0.45
post #82 of 113 Old 02-08-2013, 10:17 PM Thread Starter
JCashen
I just got home from work. Do you think the timing needs to be retarded or advanced?
JCashen is offline
post #83 of 113 Old 02-08-2013, 10:42 PM
fourbtgait
1930 MK Patriot
Lol. I have no idea. It all depends on how close it is to tdc. When i stab mine, i mark where it sits so that im fairly close to original.
If it wanted to start, it might be sitting atdc, so it needs to move to tdc or btdc.
Remember, typically it runs good at 8*btdc
post #84 of 113 Old 02-08-2013, 10:43 PM
fourbtgait
1930 MK Patriot
Ive almost finished wiring my msd. Need to go to pick and pull for one plug end so that its a clean install, hook up power/ground.
post #85 of 113 Old 02-08-2013, 11:01 PM Thread Starter
JCashen
I advanced it. Its almost started. Unless I hold the gas pedal down it won't stay running though.
JCashen is offline
post #86 of 113 Old 02-08-2013, 11:04 PM
fourbtgait
1930 MK Patriot
Try advancing a little more. Small turns.
Was it running good before you messed with it?
post #87 of 113 Old 02-08-2013, 11:15 PM Thread Starter
JCashen
Was a tired 4.2. Ran decent I wouldn't say good.
Got it to run. But now I have to figure where to install these resistor to prevent run on.
Got it set to 8btdc. But it seems off. I'd need a pro here to tell.
I might refund tdc and reseat the dizzy.
JCashen is offline
post #88 of 113 Old 02-08-2013, 11:34 PM Thread Starter
JCashen
Yeah I can't figure out this diode. Where do I need to install it? I dont want to get it in the wrong spot.
How is your install coming along?
JCashen is offline
post #89 of 113 Old 02-08-2013, 11:38 PM
fourbtgait
1930 MK Patriot
If it runs, reseating dizzy wont change anything. You cant pick up a tooth except for dizzy clearance.
Carb adjustment?
Resister goes in small brown wire on clip that comes out of top of alternator. I hear its a pain to solder in. I googled soldering diodes to stranded wire. They said to "tin" the wire first, then install diode
post #90 of 113 Old 02-09-2013, 12:40 AM Thread Starter
JCashen
Carb adjustment?
I just finished soldering mine. Man it was a pain.
It just seems off. Probably just me.
Would the engine run if the rotor was closer to the 2nd terminal than the first at tdc? Just curious how off it could be and still run.
JCashen is offline
