jeep won't start - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > YJ Wrangler Technical Forum > jeep won't start
Unread 04-16-2010, 08:30 AM   #1
Cadetvette87
jeep won't start
ok, so I seem to have a bit of an electrical problem. My jeep wasn't starting (before the battery died) and my battery was completely shot. So I went ahead and installed a new starter and a new battery yesterday. When I turned the key on I got electrical power and all was fine. As soon as I turned the key to start everything shut-off. Now I don't even get electrical power at all. I can't even turn my lights on. I took the battery back to the store. They tested it and the battery is good. I am not an electrical guy at all so I really need some help on this one. Thanks!
She never wears a top, she likes to get dirty, and she always lets me get inside...a jeep is the perfect women!
Cadetvette87 is offline   Reply With Quote Quick reply to this message
Unread 04-16-2010, 08:32 AM   #2
SkullTripper
1987 YJ Wrangler
sounds like a crossed wire to me... I'm no electrician tho... check all your fuses as well
[B][U]Its a Jeep thing....[/U][/B]
[COLOR="Lime"][B]My 1987 Jeep Wrangler Build..[/B][/COLOR]
[url]http://www.jeepforum.com/forum/f22/z-o-r-v-87yj-build-slow-978747/[/url]
SkullTripper is offline   Reply With Quote Quick reply to this message
Unread 04-16-2010, 08:35 AM   #3
Outlaw
I second the motion . . .
Outlaw is offline   Reply With Quote Quick reply to this message
Unread 04-16-2010, 07:18 PM   #4
bharris68
What other Electrical items do you have?
bharris68 is offline   Reply With Quote Quick reply to this message
Unread 04-16-2010, 08:04 PM   #5
MJMPC
Clean or replace your battery cables.
MIKE
http://www.dav.org/
MJM Powder Coating
Elizabethtown Ky.
http://www.cityprofile.com/
MJMPC is offline   Reply With Quote Quick reply to this message
Unread 04-16-2010, 08:13 PM   #6
outlawjeeper
second the battery cables
outlawjeeper is offline   Reply With Quote Quick reply to this message
Unread 04-16-2010, 08:38 PM   #7
SkullTripper
1987 YJ Wrangler
Whats up with all the outlaw guys just seconding things.. >.>
Unread 04-16-2010, 09:22 PM   #8
Old4X
1990 CJ7
You are experiencing a high voltage drop under load. Most likely cause (as mentioned above) is a broken or corroded battery cable and/or connections at the battery, starter, grounds, or starter relay.
If your cables are original to the Jeep, toss then, they are more than 20 years old and should be replaced. They break down internally due to corrosion of both the cabling itself and where the connectors attach to the copper cables.
418 miles on 19 gallons of gas. Can't beat the BBD !
Old4X is offline   Reply With Quote Quick reply to this message
