Jeep won't shutoff - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > YJ Wrangler Technical Forum > Jeep won't shutoff
Unread 08-15-2009, 10:49 AM   #1
RebuildRookie
Jeep won't shutoff
I can crank it just fine, but when I turn the key off it still runs even if I pull the key all the way out. I got a good idea of what it might be, but I would like some input before I start spending money.
[FONT="Century Gothic"][B]I'm a more proactive person.
You spray the ants before they get in your house.
You plant the crops before you starve.
And you keep the terrorists in check before you get your *** blowed off.[/B][/FONT]
RebuildRookie is offline   Reply With Quote Quick reply to this message
Unread 08-15-2009, 11:16 AM   #2
ziebartrob
I would say your ign cyl is bad.
ziebartrob is offline   Reply With Quote Quick reply to this message
Unread 08-15-2009, 12:07 PM   #3
RebuildRookie
Yeah I have noticed that I have to turn the key back just a little because it wont turn back on its own after I turn it to start it.
Any Ideas if that dont work.
The only way to kill the motor is to disconnect the battery.
Unread 08-15-2009, 12:42 PM   #4
RebuildRookie
What if I just put in a 3 way toggle switch- 1 off 2 run condition 3 start condition springs back to 2 position.
And a seperate 2 way kill switch hidden.
How hard would that be? Would anyone do it to there rig.
Unread 08-15-2009, 05:20 PM   #5
RebuildRookie
Changed the Ignition Key Cylinder. Still wont shut off.
Any help is greatly appreciated.
Unread 08-15-2009, 05:55 PM   #6
Fhajad
To do the three way switch should be easy. As long as you get a switch that holds the proper amperage and such. I think 40 does it, since 40 is the fuse size for my starter.
I have a kill switch for my ignition wire from the steering column to the starter motor. It's incredibly easy to wire.
Fhajad is offline   Reply With Quote Quick reply to this message
Unread 08-15-2009, 10:12 PM   #7
1997_Sport
Maybe it was converted to diesal overnight?
But i think it would be easier to just go with a kill switch. So you can just remove the key and hit the switch and its off.
1997_Sport is offline   Reply With Quote Quick reply to this message
Unread 08-15-2009, 10:53 PM   #8
timatoe
I would check the ignition switch on top of the column behind the dash, I think it's about $15.
timatoe is offline   Reply With Quote Quick reply to this message
Unread 08-15-2009, 11:16 PM   #9
Ironworker709
Ironworker709's Avatar
I know its not a Jeep,but that was the EXACT problem in one of my old F150's with the same symptom,...wouldnt shut off.
By the way..this is a REAL change,usualy the headliner is"help,my jeep won't start!".......lol
Ironworker709 is offline   Reply With Quote Quick reply to this message
Unread 08-15-2009, 11:53 PM   #10
RebuildRookie
yeah i had one of those headlines a while back now I cant get this sled to quit running. lmao
Diesel yeah thats some funny $h*t sometimes I wish it was. hehehehe
Unread 08-18-2009, 07:03 PM   #11
RebuildRookie
Changed out the ignition switch no luck still wont shut off.
Anymore suggestions.
Unread 08-18-2009, 07:19 PM   #12
Fhajad
Should probably try a fuel pump kill switch.
Unread 08-18-2009, 07:24 PM   #13
xWhite420wIDOWx
1967 CJ5
Hahaha LMAO=-)
xWhite420wIDOWx is offline   Reply With Quote Quick reply to this message
Unread 08-18-2009, 08:06 PM   #14
RebuildRookie
I would put a kill switch on my fuel pump, but I would still have a drain on my battery. The ebrake light stays on when they key is in the off position and after I pop the clutch to kill the motor. So somewhere when I turn the key off it is not sending a killing the power.
Unread 08-18-2009, 09:06 PM   #15
Ironworker709
Did you check this yet?..this is the actual box that controls everything,the key cylinder just controls this box for ignition
