Jeep wont inc. in rpms when i hit 4th - JeepForum.com
post #1 of 18 Old 11-11-2013, 02:36 PM Thread Starter
jimhill
It will drive fine up until 4th gear then I push on the gas and no matter how much I push the accelerator my rpms stay the same no power :\ also I don't have to push down my brakes as much to brake what could that be?
jimhill is offline
post #2 of 18 Old 11-11-2013, 04:51 PM
Mark05059
Just as a guess... Im going to say a stuck caliper on the front.. drive for a while and then touch the wheel.... if its too hot to touch... then you have found the issue. Probably both issues actually
1998 ZJ 5.2 Auto
1989 Wrangler Black Bone Stock 2.5l 5spd
/l , [____],
|---L--[]lllllll[]-
()_) ()_)==O=)_)
Mark05059 is offline
post #3 of 18 Old 11-11-2013, 05:25 PM Thread Starter
jimhill
Thank you I will definitely try this!
jimhill is offline
post #4 of 18 Old 11-12-2013, 10:58 AM
jred
Does it kind of bog down a bit? Might be fuel filter.
jred is offline
post #5 of 18 Old 11-12-2013, 11:28 AM
jokerchief462
Plugged catalytic converter.
Sent from underneath my Jeep
89YJ 2.5L TBI, AX-5, NP231 SYE, Ford 8.8, Yukon Grizzly, Tom Woods Shaft, 33" BFG T/As, 4" lift, Warn VR10000s.
AF Jeep Club Tail #184
jokerchief462 is offline
post #6 of 18 Old 11-12-2013, 12:47 PM Thread Starter
jimhill
I just replaced the fuel filter and it made it work great for about a month
jimhill is offline
post #7 of 18 Old 11-12-2013, 12:50 PM Thread Starter
jimhill
I just replaced the catalytic converter in may it should be fine
jimhill is offline
post #8 of 18 Old 11-12-2013, 01:52 PM
SeanB95YJ
the fact that changing the filter cured the problem momentarily, my guess is that you've got some sort of crud (rust maybe?) in the tank and now your filter is clogging up again.
run the tank as close to empty as you can and drop it down, pull the sender and inspect the inside. might be (over) due for a good flushing out, or maybe even replacing (20 gal poly )
Good luck
Sean B. - Schenectady, NY - 95 YJ, 350/700r4/NP241, JB Shorty SYE, 8.8 rear, 2" BDS, 1" homebrew shackles, Daystar 1" BL, TJ flares, 35x12.50 General Grabber AT2 on 15x10 Bart D-Truckers, Polyshield polycarbonate windshield, HD over/under crossover steering
swap/build thread:
SeanB95YJ is offline
post #9 of 18 Old 11-12-2013, 03:59 PM Thread Starter
jimhill
Good luck
Thanks ill look into that to
jimhill is offline
post #10 of 18 Old 11-13-2013, 06:59 AM
Que89YJ
Is it Nuttered?
Que89YJ is offline
post #11 of 18 Old 11-13-2013, 03:09 PM Thread Starter
jimhill
Originally Posted by Que89YJ
Is it Nuttered?
What does that mean?
jimhill is offline
post #12 of 18 Old 11-13-2013, 05:14 PM
Que89YJ
Has the nutter bypass mod been done? Look in the faq. for a description. It bypasses the computer.
Fault codes:
Mean Max pics of everything:
No Start:
Que89YJ is offline
post #13 of 18 Old 11-13-2013, 05:46 PM Thread Starter
jimhill
No I did not nutter it is this something you would recommend?
jimhill is offline
post #14 of 18 Old 11-13-2013, 05:59 PM
Que89YJ
If you are not in an emissions test state then not only yes but hell yes. The nutter along with a hei setup or the team rush mod would make an unbelievable performance difference.
Fault codes:
No Start:
Que89YJ is offline
post #15 of 18 Old 11-13-2013, 06:09 PM Thread Starter
jimhill
Well I'm out then cause I live in Pennsylvania :\ why does it affect the emissions?
jimhill is offline
