jeep wont go after clutch/tranny rebuild - JeepForum.com
post #1 of 6 Old 02-13-2013, 06:26 AM Thread Starter
Juggalo
92 2.5 with ax5. pulled tranny and transfer case and had mechanic put in a rebuild kit in the ax5. while out i put in a new rear main seal and a new clutch and slave. put it back together and it starts up fine but when i disengage the clutch, the jeep bogs down and dies. the best way to describe it is that it feels like the wheels are all locked in place and wont let the jeep roll. also with the transmission in neutral, when i let out on the clutch it bogs down and dies, like its still in gear. it feels like a clutch issue. any thoughts?
Juggalo is offline
post #2 of 6 Old 02-13-2013, 09:27 AM
jhartley
Sounds like something's wrong with the transmission, as in its in two gears at the same time
jhartley is offline
post #3 of 6 Old 02-13-2013, 11:03 AM
JeepinJeremy
When you put the transmision back in did you have it in nuetral or in gear? If you had it in nuetral you could have shifted a shift fork locking up two gears. I bet if you pulled the transmision back out you will now find you can not shift it into any of the gears. AX5 tranys do this. Transmission must me in 1st or 3rd when removed and installed the same way. Shifter housing must be installed while transmission is in nuetral. Heres a link http://www.diystew.com/wp-content/up...3/ax5Trans.pdf
JeepinJeremy is offline
post #4 of 6 Old 02-13-2013, 11:06 AM
JeepinJeremy
You will have to pull it out anyhow now and realign the shift forks. the link I posted will tell you how. Good luck
post #5 of 6 Old 02-19-2013, 11:53 AM Thread Starter
Juggalo
Well I removed tranny (Again!) and loosened the rear cover. As soon as I did that it was possible to spin the input shaft freely and it seemed to shift ok. I reassembled and reinstalled and 1st-4th work great but now I cant shift into 5th or Reverse????? WTH?
Juggalo is offline
post #6 of 6 Old 04-13-2013, 12:19 PM
JeepProblems
hey man im having a similar issue. when i put the case on it, nothing will spin!! i was expiramenting and found out that if i loosen the input shaft retainer it will spin. almost like theres is too much pressure pushing on the shaft so it just binds up. i had to replace the 1st gear, inner race and needle bearing and the company that i got it from sent me a wrong one. fine. got another and am having the same issue! thinking its the inner race thats too long because both gears came with the same race and when i press on the bearing then 5th gear, there is not enough room for the snap ring. im guessing this clearance is causing everything to bind up.
JeepProblems is offline
