Jeep won't cut off - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > YJ Wrangler Technical Forum > Jeep won't cut off
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineFLASH SALE! Open thread to reveil the Newest Sale @ ROCKRIFS: Wrangler RGB Multicolor Fog Light LEDs: Awesome Effect
Unread 04-22-2013, 01:50 PM   #1
lbhutch03
Jeep won't cut off
I have a 4.0 in my jeep. When I turn the key off the motor keeps running for another 10 to 15 seconds. It seems to keep running until it runs out of fuel. Any idea what could be causing this and how to fix this problem?
lbhutch03 is offline   Reply With Quote Quick reply to this message
Unread 04-22-2013, 02:29 PM   #2
Siva283
Are you sure its not the 4.2? Was the engine swapped? Your year came with the 4.2 if i am not mistaken
[QUOTE=Magnum;14117863] I gave the Jeep the required offering of $$, sweat, and blood, and everything works fine now. -- Jim[/QUOTE]
[QUOTE=ldso;16498409]. It started with a $200 axle, and a few thousand dollars later I was done :)[/QUOTE]
[QUOTE=Luuca;16122017]diagnose the real issue before you start going all Obama on it - spending mad cash you'll need for other important things.
Ask me how I know...[/QUOTE]
[QUOTE=Overhead;17658665]this is also my second set of RC springs this year. I'd rather spend the money again and get something that will last.[/QUOTE]
Siva283 is offline   Reply With Quote Quick reply to this message
Unread 04-22-2013, 02:39 PM   #3
lbhutch03
Yeah the motor was switched to a 4.0.
Unread 04-22-2013, 02:41 PM   #4
Siva283
I got nothing for this issue with the 4.0. I am sure Que or Pete will be along shortly. They will get you straightened out.
Unread 04-22-2013, 02:47 PM   #5
roadyrob
1987 YJ Wrangler
couple of questions, is the 4.0 carbed or FI? when you say keeps running does it run smooth or rough? dieseling will do what you discribe but it won't be running smoothly. its caused by carbon build up in the motor.
Do everything with a positive attitude, it won't always work but you'll piss enough people off to make it worthwhile.
the voices aren't real but they sure have good ideas.
roadyrob is offline   Reply With Quote Quick reply to this message
Unread 04-22-2013, 04:00 PM   #6
lbhutch03
It is fuel injected. Once I turn the key off, it will run smooth for about 5 seconds. Then I will start running a little rough until it dies.
Unread 04-23-2013, 11:36 AM   #7
lbhutch03
And if it is carbon build up, what causes this and how do I fix it?
Unread 04-23-2013, 11:46 AM   #8
roadyrob
1987 YJ Wrangler
carbon build up is caused by a rich condition, usually doesn't happen to FI motors unless they have had a problem. what happens is the carbon gets hot and keeps igniting the fuel after shutdown. easiest cure is seafoam. heres a thread that tells you how to do it.
http://www.jeepforum.com/forum/f11/sea-foam-99405/
Unread 04-23-2013, 11:55 AM   #9
NonRubicon
Check for any codes too. They'll alert you to any problems known to the computer.
NonRubicon is offline   Reply With Quote Quick reply to this message
Unread 05-12-2013, 04:38 PM   #10
lbhutch03
Ok, after some digging around I found that I still have spark once I turn the key to the off position.. I found that if I pull the coil plug right after I turn the key off, the jeep dies. I put a test light on both wires going to the coil, and they are hot with the ignition off. Any ideas what is causing this?
Unread 05-13-2013, 10:29 AM   #11
Que89YJ
Yes, you need the diode across the alternator. I bet you are using the internally regulated alternator with the fuel injected system.
http://www.jeepforum.com/forum/f12/9...36-amp-610349/
Que89YJ is offline   Reply With Quote Quick reply to this message
