Jeep won't turn off! - Page 2 - JeepForum.com
post #16 of 25 Old 03-15-2006, 04:59 PM
GroundClearance
GroundClearance's Avatar
It idles fine normaly, just when you shut off the ignition that it starts getting rough.
'02 Wrangler TJ
'04 Rubi
'88 Wrangler YJ
'94 Grand Cherokee ZJ RIP FEB 25 2006
'47 CJ2A
Originally Posted by knatdog55
matt, you are a dirty hooker, deal with it....
U.S. NAVY JEEP HULL # 41
NOW WORKING
GroundClearance is offline
post #17 of 25 Old 03-15-2006, 05:04 PM
jipjip
jipjip's Avatar
to the OP, you have a bad ignition switch, or key cylinder.....it's not switching power off to the ignition and fuel pump, so the engine stays running... most of the time the key cylinder goes bad first.... especially in jeeps this old. mine had the same problem, replaced the key cylinder, problem solved.
good luck
95 yj sahara green w/ spice hard and soft top, bikini top,full steel doors, and 2 piece bestop soft doors,tnt customs front tube fenders w/ 6" flare,warn gas tank skid, skidrow oil pan skid,4.0HO,rear 31 spline 8.8 w/ disc brakes,4.10's and lsd,front HP d30 w/ 4.10's and aussie front locker,ax15,np231j w/ jb conversions ss sye, tom woods custom cv d/s,RE 4.5xd,35" toyo open country m/t's, 1" daystar body lift, warn 9.5ti
jipjip is offline
post #18 of 25 Old 03-16-2006, 04:32 AM
Bobbywolf
Bobbywolf's Avatar
have you done any work to your alternator? If you bypass the resistive wiring on terminal #1 of your alternator plug, your jeep wont shut off either because of the back voltage. Long shot I know, but it happened to me this weekend when troubleshooting a charging problem.
Bobbywolf is offline
post #19 of 25 Old 03-17-2006, 03:50 AM
jeezer93
I would still check the ignition switch. I don't think it is dieseling if the guages still work when the ignition is turned off. I have seen ign switches go bad and do exactly as you describe. In a perfect world it might go bad and give you full battery voltage when the key is off and run smooth. However, I would lean towards it being bad and not giving full battery voltage. Engine's can run like crap when the computer, fuel pump etc... don't receive good power. Good luck and let us know what you find.
jeezer93 is offline
post #20 of 25 Old 11-07-2013, 09:09 PM
duztytrue
Yeah my 90 yj is doing the same thing. I changed the ignition lock, ignition switch, i checked the rod all is fine there too! I am at a loss.
duztytrue is offline
post #21 of 25 Old 11-08-2013, 12:59 PM
Mark05059
zombies are among us!!
this died 7 years ago... make a new thread
1998 ZJ 5.2 Auto
1989 Wrangler Black Bone Stock 2.5l 5spd
/l , [____],
|---L--[]lllllll[]-
()_) ()_)==O=)_)
Mark05059 is offline
post #22 of 25 Old 11-08-2013, 01:30 PM
bpounds
bpounds's Avatar
He did.
http://www.jeepforum.com/forum/f12/j...nning-1764697/
Apparently he didn't like our suggestions.
Bill
Dodge did not build my Jeep.
1988 Wrangler,4.2L I-6, Howell EFI JP-1,GM HEI Ign, 5 Speed Peugeot, Zone 2.5" lift + 1/2" booms, BFG 31 x 10.5, Bestop.
bpounds is online now
post #23 of 25 Old 11-09-2013, 07:07 AM
duztytrue
I am trying the suggestions it just takes me while to respond sorry
post #24 of 25 Old 11-14-2013, 08:21 PM
duztytrue
Got it just checked all connections and must of had a loose one.
post #25 of 25 Old 11-15-2013, 11:08 AM
bpounds
bpounds's Avatar
Glad you got it. But I don't believe a loose connection would cause the engine to run-on. Something was shorted somewhere. And if you didn't actually find it, it may come back.
Bill
Jeep won't turn over jeffmc TJ Wrangler Technical Forum 21 03-06-2011 06:41 PM
Jeep won't turn over... usetobejeeper TJ Wrangler Technical Forum 4 08-17-2010 01:29 AM
Turn singal does not turn off when I turn left. MWguy101 YJ Wrangler Technical Forum 31 02-14-2010 04:21 PM
my jeep wants to turn off metalroses YJ Wrangler Technical Forum 8 07-20-2009 01:58 PM
Jeep won't turn over on first try!! mudslingertj24 TJ Wrangler Technical Forum 3 07-29-2008 08:06 AM
