Jeep Won't Start When Hot - JeepForum.com
post #1 of 4 Old 09-03-2011, 02:25 PM Thread Starter
cstone94
After driving for even 10 minutes, then stopping, my 2.5L jeep won't start. It seems like it's not getting gas maybe? It will just wind the starter and every now an then, get a little flutter. After trying and trying for 20 minutes, the fluttering gets more often and then finally it chunks at 200rpm until the choke kicks on. Then once I get going, there are small combustions in the cold air intake. It does have a throttle body spacer, and it HAD a header on it. Could it be that it's something in the fuel lines? Help!
cstone94 is offline
post #2 of 4 Old 09-06-2011, 10:14 AM
Que89YJ
Check for gas and the schrader valve on the fuel rail and spark at the plugs when it's not starting. Also check for fault codes. if you think its a fuel problem then spray a little starting fluid into it when you are having the problem and see if it cranks.
Que89YJ is offline
post #3 of 4 Old 09-06-2011, 03:47 PM Thread Starter
cstone94
Spark is fine and just changed the plugs. I took off the air filter and the tubes, and looked into the throttle body and it was black, so i got some throttle body cleaner and got liberal with it. It now starts fine. I also checked the error codes using the 3 key turns and i got, 12, 33, 14, 14, 21, 21, 55(end).
cstone94 is offline
post #4 of 4 Old 09-06-2011, 03:53 PM
Que89YJ
Disconnect the battery for a long 10 count to clear the codes. Start it and run it for 20 minutes and recheck your codes.
Que89YJ is offline
Jeep Wouldn't Start, Then Started, Now Won't Start - No Error Codes? drb TJ Wrangler Technical Forum 3 08-26-2011 12:50 AM
Jeep won't start - Starter doesn't start cooltc2004 YJ Wrangler Technical Forum 5 12-29-2008 10:36 AM
whats wrong with my jeep need answer asap (Jeep won't idle after jump start) Wrangler11 TJ Wrangler Technical Forum 24 11-04-2008 04:46 PM
Jeep wont start advice on where to start? vangosu TJ Wrangler Technical Forum 6 08-25-2008 08:28 AM
Wipers start when I start the jeep Rock & Roll TJ Wrangler Technical Forum 3 09-07-2005 10:12 PM
