Jeep won't start - Starter doesn't start - JeepForum.com
post #1 of 6 Old 12-29-2008, 07:31 AM Thread Starter
cooltc2004
I come outside this morning to leave for work, and my Jeep doesn’t want to start. I turn the key to the “ON” position, and you can hear the fuel pump do its cycle. When you turn the key to the start position you can hear the fuel pump pump, but the starter doesn’t engage and turn over the engine. My first thought is the ignition switch, since it seems like every vehicle I own has the same damn problem. It eventually did start, but it took a while. Anything else I should look at?
1988 Jeep Wrangler YJ
cooltc2004 is offline
post #2 of 6 Old 12-29-2008, 08:29 AM
bigsquat
read this thread, it should give you some ideas to look aT http://www.jeepforum.com/forum/f12/jeep-will-not-start-not-starter-battery-644322/
red 92 yj,4.0,dana 44 rear,xj driveshaft,rubi 4-1 tc,35"tires,smitty built winch,oba, 6" flares,hand throttle,aussie's front and back,posi-lock,6" lift.anti-wrap, hombrew bumpers, rack and sliders,cb,rear shock truss <>< ,MY BUILD:
Two fish swim into a concrete wall. One turns to the other and says 'Dam!'
bigsquat is offline
post #3 of 6 Old 12-29-2008, 08:32 AM
chimmychanga
you can also have somebody give the starter a whack while you are turning the key. Sometimes there is a deadspot in there and a whack will help it get by. The starter will likely need to be replaced.
chimmychanga is offline
post #4 of 6 Old 12-29-2008, 10:21 AM
TWISTED125
replace the starter, get rid of the core. Just did mine, got out for 60 bucks after i gave them my shot starter, 60 bucks for peace of mind knowing its new and has a lifetime warranty - priceless.
TWISTED125 is offline
post #5 of 6 Old 12-29-2008, 10:29 AM
bigsquat
i would do a little trouble shooting before you just start replacing parts. why spend money on parts that are good if you dont have to. unless moneys no object. go and but a starter, battery, cables, starter relay, ignition switch
bigsquat is offline
post #6 of 6 Old 12-29-2008, 10:36 AM Thread Starter
cooltc2004
Well my plan was never to throw parts at the problem. I'll take a look at the starter, I know I was having a similar problem on another car and the cables were loose on the starter. Only thing different is that after a little bit she did start up, and I didn't wiggle any cables or push/roll the Jeep.
Jeep Will Not Start, Not the Starter or Battery 92yjokc YJ Wrangler Technical Forum 130 10-14-2010 10:28 PM
Jeep will not start, starter screams redmudjeep YJ Wrangler Technical Forum 27 11-16-2009 01:28 PM
Dead Jeep, jumped starter won't start, looking for advice MK116V TJ Wrangler Technical Forum 22 09-28-2009 06:04 AM
Please help!!! Jeep won't start but battery and starter are good usmcwrangler YJ Wrangler Technical Forum 10 09-14-2008 05:58 PM
need to start a stick-5sp-jeep without a starter farinspace TJ Wrangler Technical Forum 33 11-14-2007 10:38 PM
