Jeep will not start/run - JeepForum.com
post #1 of 3 Old 08-26-2011, 06:49 PM Thread Starter
Cross
The Jeep was running fine then the other day I jump in it and it fires up then rpms drop steadily until it dies. Now when it does fire the rpms go up to about 1000 then it drops and shuts off. I have replaced the MAP and TPS sensor and nothing has changed. At one point I tried starting the Jeep without the MAP sensor plugged in the Jeep would start but idle very rough, if I hit the accelerator it would die. One time while just letting it idle rough all of a sudden it went up to about 2000rpm and dropped jump up again then dropped until it dies. for the most part I cannot even get it to start now. At times with the ignition turned it is firing and trying to start but as soon as you let go of the ignition it dies. I am at a loss to what is going on and how to fix it.
Sierra Club, helping to confine humans within city limits one acre at a time.
Cross is offline
post #2 of 3 Old 08-26-2011, 06:55 PM
tobias94yj
Hillbilly Member
tobias94yj's Avatar
I know this generic but have you ruled out the simple stuff like the dist. cap and rotor and maybe even the coil and the coil plug? also are you getting a CEL? if so have you checked to see what code it is throwing?
To view the NEW
click here!!!
tobias94yj is offline
post #3 of 3 Old 08-26-2011, 07:51 PM
oldtime_ironman
Whats your fuel pressure look like? Should be about 31 PSI.
Only other things that come to mind would be the IAC valve and the cam position sensor - since the cam sensor tells it when to fire, it can mess with the timing. And you know how changing the timing can change the RPM's.
oldtime_ironman is offline
Jeep Wouldn't Start, Then Started, Now Won't Start - No Error Codes? drb TJ Wrangler Technical Forum 3 08-26-2011 01:50 AM
Jeep won't start - Starter doesn't start cooltc2004 YJ Wrangler Technical Forum 5 12-29-2008 11:36 AM
whats wrong with my jeep need answer asap (Jeep won't idle after jump start) Wrangler11 TJ Wrangler Technical Forum 24 11-04-2008 05:46 PM
Jeep wont start advice on where to start? vangosu TJ Wrangler Technical Forum 6 08-25-2008 09:28 AM
Wipers start when I start the jeep Rock & Roll TJ Wrangler Technical Forum 3 09-07-2005 11:12 PM
