Jeep Tutorial - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > YJ Wrangler Technical Forum > Jeep Tutorial
Savvy Billet LED Tail LightsLight up the holidays with LED lights from JeepHutIntroducing MONSTALINER™ UV Permanent DIY Roll On Bed Line
Unread 12-16-2014, 07:45 PM   #1
wichoarriaza
Jeep Tutorial
Hello guys,
I am new with Jeeps, I own a 1993 YJ 4.0 Automatic and a 1989 YJ 4.2 Manual.
If anyone can help me with the specs or tutorial about engines, transmissions, axels, brakes, differences, etc on these models it would be deeply appreciated.
I would also like to know what is the best way to improve the performance on my automatic transmission since I have 33x12.5R15 tires and it just wont stop shifting up and down while I drive. Guess its because of the tire size.
Thanks
wichoarriaza is offline   Reply With Quote Quick reply to this message
Unread 12-16-2014, 08:39 PM   #2
Louie4
Powah Injanir
Louie4's Avatar
The Frequently Asked Question Thread is a good place to start for YJ information.
http://www.jeepforum.com/forum/f12/y...-first-580536/
As for the transmission, I would change the fluid and add a stand alone cooler. Then start looking into axle gear ratios based on your engine and tire size.
Lou
YJOTM July 2012
YJOTM February 2014
Louie4's YJ Build
Poison Spyder Fender Install
Warn M8000 Rebuild Adventure
University of Georgia
Louie4 is offline   Reply With Quote Quick reply to this message
Unread 12-16-2014, 08:46 PM   #3
ROWA
ROWA's Avatar
Check the FAQ section there is a lot of useful information about specs. Your shifting problem is related to your gear-ratio, with an auto and 33" tires a 4.56 would be the ideal solution.
94 YJ Sahara
The best Engineering is no match against natural Stupidity.
ROWA is offline   Reply With Quote Quick reply to this message
Unread 12-16-2014, 08:47 PM   #4
Luuca
Professional Novice
Luuca's Avatar
Originally Posted by wichoarriaza View Post
Hello guys,
Thanks
Hola!
Bienvenido a los foros! Mi esposa es de Cobán, Guatemala. Es muy extraño para ser nuevo para Jeeps y poseer dos. jaja
Los miembros de esta sección lo ayudan con cualquier problema que usted tiene, pero no hay una sola explicación para todo el yj jeep. Si usted tiene un problema o tema específico, utilice la función de búsqueda de los foros técnicos YJ. Use palabras clave que se centran en la pieza o el problema que está teniendo como "sobrecalentamiento". Si usted no puede encontrar el tema ahí, sólo hay que preguntar, o publicar su pregunta en un hilo más viejo, así que aquellos que han respondido previamente puede ayudarle.
Haga sur de llenar el perfil del vehículo en los foros - ya que tienes dos YJs, rellene el uno para el conductor diario. Eso es todo.
Una vez más, la bienvenida a los foros!
91 YJ "Alice" 2.5L AX5 D30/35 -Busted Knuckles Yellow Jeep Club #91
05 LJ Rubicon "Ghost" 4" RE Lift 1" BL 33s
Luuca is offline   Reply With Quote Quick reply to this message
