Jeep Towing - JeepForum.com
post #1 of 4 Old 03-26-2002, 10:09 PM Thread Starter
Coot
Jeep Towing
I will be pulling my jeep from PA back to Texas I plan to use a tow bar. Will I need to disconnect the drive shafts? What kinda tow bar is best for a jeep? The shackles have pin's in the front can the tow bar be hooked to it? If you could think of anything esle that I need to know to tow it please reply. Please reply quick because I am planning on making the trip on saturday. If it matters it has a 4 inch suspension lift and stock tires.
Thanks,
The Coot
92 Jeep YJ, 4 Banger, Cold air intake, Electric fan, 1 inch motor mount lift, 8.8 rear axle Limited Slip 4.10's, SOA, 2 inch body, 35x12.5 Pro Comp MT on 15x8 AR-767
Coot is offline
post #2 of 4 Old 03-27-2002, 09:42 AM
osburn
osburn's Avatar
Put the tranny in 5th, the tcase in neutral, and put the key in the ignition and turn it to the 1st click so the wheel moves freely but no electronics are enabled. You shouldn't have to disconnect driveshafts. Some do, but they're usually are locked in the front. As long as your alignment is not too far out of whack, it should tow fine. Keep your speeds down. Stopping that much weight without any sort of trailer brakes is a task.
Matt Osburn
Score 1032
osburn is offline
post #3 of 4 Old 03-27-2002, 09:26 PM
RodeoRob
RodeoRob's Avatar
Whats gonna be the towing vehicle? The most important thing when flat towing is you'll need a tow'er much heavier than the tow'ee. If the vehicles are too close to the same weight, you're asking for disaster. Also remember, when you're flat towing, there's no backing up without unhitching the vehicles.
I flat towed a YJ from UT to NC behind the back of my Isuzu with relatively no problems. However, A buddy of mine tryed to flat tow the same YJ with his XJ and got jack knifed off the road... lucky no damage was done.
Theres a discussion about flat towing going on over on POR right now.
-Rob
Robert Gorrell
1995.5 Isuzu Rodeo - SAS'd and SOA'd, sitting on 36x12.50 TSLs, D44 front, 14bff rear, locked by OX and Detriot, suspensions by Jeep and Chevy, high steer conversion, 5.13 gearing and Teralow in the case.
RodeoRob is offline
post #4 of 4 Old 03-28-2002, 08:23 PM
4wheeler4CJ
4wheeler4CJ's Avatar
I don't want to start a "conflict", but, how the hell much heavier can an Isuzu Rodeo be than an XJ, that there could be that much difference? Sounds more like a difference in "driving/towing experience".
4wheeler4CJ is offline
towing my jeep George Ransom YJ Wrangler Technical Forum 3 10-18-2007 08:09 PM
Towing my Jeep gustaia YJ Wrangler Technical Forum 10 03-18-2005 06:28 PM
Towing A Jeep MILKYWAY0075 YJ Wrangler Technical Forum 4 07-01-2003 08:41 AM
towing jeep fuzzman50 TJ Wrangler Technical Forum 4 05-19-2003 09:49 PM
Towing a Jeep?? blaznjeep YJ Wrangler Technical Forum 17 01-10-2003 06:11 AM
