JEEP SWAP EXPERTS! yj/yj 4.2 to 4.0 wiring harness help - JeepForum.com
post #1 of 9 Old 02-05-2010, 02:21 AM Thread Starter
92_punisher
i need the bulkhead wiring diagrams for 87 4.2l and for 93 4.0l
they would be really helpful seeing as i am now in the process of mating all the wires and its pretty time consuming trouble shooting each individual wire...
so far i have the ignition done
i still am trying to figure out the fuel pump and gauges
not much posted out there for yj/yj swaps
anything will help
thanks.
92_punisher is offline
post #2 of 9 Old 02-05-2010, 05:17 AM
Alfons
If you send me your email address, I can help you with the 4.0 wiring, unfortunately I have very little that would be useful for the 4.2.
Have a look at this from Pirate 4x4, it should be helpful for the older tub wiring.
Alfons is offline
post #3 of 9 Old 02-14-2010, 09:37 PM
orichierich
I have the bulkhead pin outs for the 1988 and 1989 yj, I just wired up my 90 yj with a 93 xj harness today (head swap and efi). I found that my 90 is the same as the 88 and 89 and i understand that although the colors of the wires have changed the pin out locations have not changed from 1987-1990 so this should work for you, it worked for me today!! message me your email address and ill send you the stuff I used today.
STOCK JEEPS (used to) RULE!!!!!!!!!
Originally Posted by RikRotorhead
Why.... some of my best friends have round headlights.
Originally Posted by Jeebs View Post
Dang! I guess thats why they're affectionately called ProCrap!
orichierich is offline
post #4 of 9 Old 02-07-2014, 12:58 PM
rsmitty1956
bulkead pinouts
Hi there trying to do the same thing. I know this is an old post, but I could use that pinout to rewire my jeep for EFI.
Thanks!
rsmitty1956 is offline
post #5 of 9 Old 02-07-2014, 02:09 PM
Mark05059
I think if you search some more there is a pinout posted in other threads
1998 ZJ 5.2 Auto
1989 Wrangler Black Bone Stock 2.5l 5spd
/l , [____],
|---L--[]lllllll[]-
()_) ()_)==O=)_)
Mark05059 is offline
post #6 of 9 Old 02-07-2014, 02:17 PM
skyj
This is the best I've seen so far.
http://www.jeepforum.com/forum/f12/4...build-1114875/
build thread:
skyj is offline
post #7 of 9 Old 02-07-2014, 02:26 PM
rsmitty1956
Changing the subject a bit
That IS a great site! That will help in the next few weeks.
BTW I did the 4.2 4.0 head swap, kept the Carter BB carb, and it is just a slow as it's ever been. I suspect the cat, but I had slugginess just going uphill with the muffler disconnected to the muffler shop.
What could possibly be the prob? Burned 10 gals for 60 miles!! ouch!
I know there are variables to consider, but gosh! This is sickening!
Any help would be greatly appreciated. Sorry if in wrong post for this, new here!
post #8 of 9 Old 02-07-2014, 03:05 PM
YJ4LIFE
I have alot of info at home. I'll link you later.
'89 YJ, 4.2L, ax-15, B&M shifter, 1" BL, TJ flares, '99 intake, '91 EFI, 5.0L explorer injectors, GenRight tank & stretch, 35" ProComp Xtreme muds, 52" chevy springs rear, 44044 Ranchos front.....
YJ4LIFE is offline
post #9 of 9 Old 02-07-2014, 03:54 PM
YJ4LIFE
That's rediculous. 6mpg. my worst was 9-10 mpg ever. it was 13 before the last time it went out. 9-10 was with the with the ford autolite mc2100 that was possessed by the devil.
YJ4LIFE is offline
Wiring problems after swap, which harness will work? Drdan524 YJ Wrangler Technical Forum 1 05-03-2009 12:20 PM
92 Wiring harness toasted/engine swap wrose95174 YJ Wrangler Technical Forum 1 03-21-2009 07:32 AM
Radiator, Wiring Harness, Headers for V8 Engine Swap simpsonsdotcom TJ Wrangler Technical Forum 15 04-24-2008 11:12 AM
2.5 to 4.0 swap wiring harness.. mbe25 YJ Wrangler Technical Forum 16 03-17-2007 08:25 AM
TPI into Jeep firewall wiring harness Qdanj YJ Wrangler Technical Forum 0 02-28-2006 01:27 PM
