Jeep stuck on hill in branches - JeepForum.com
post #1 of 99 Old 02-18-2012, 10:27 PM Thread Starter
SKYOFSCORPIONS
So my Jeep is about 15 min drive from my house, I had to leave it there overnight because it became stuck. It's on a long grassy hill, a little slippery. There are 2 branches under the jeep touching the skid plate, there is one big branch in front of the Jeep. What do you think is the best method for getting this out? Chainsaw the branches and lower the air in the tires for traction and then go forward out of it? :/
SKYOFSCORPIONS is offline
post #2 of 99 Old 02-18-2012, 10:46 PM
Anticanman
RIP one good jeeper
Anticanman's Avatar
Chainsaw only if you have permission from the landowner or whomever manages the property then try to air down and make it out. If you have a friend with a winch that would help. Bring a friend with ANYTHING!
Luck Favours The Prepared
Anticanman is offline
post #3 of 99 Old 02-18-2012, 11:04 PM
BackRoadJPin
1995 Wrangler
BackRoadJPin's Avatar
Always off-road using the buddy system. Some one with a winch would be helpful. Take your time on the recovery and think the moves through before executing you can end up in a worse predicament.
Back Road Jeepin
BackRoadJPin is offline
post #4 of 99 Old 02-18-2012, 11:08 PM
BackRoadJPin
1995 Wrangler
You could also try posting up in here, and or find local to you off-road clubs, some people in groups love a good recovery trip.
Back Road Jeepin
post #5 of 99 Old 02-18-2012, 11:16 PM Thread Starter
SKYOFSCORPIONS
Thanks guys! I called a towing company and they said they would chainsaw the branches but would charge sooo much money. SO I was thinking of renting a chainsaw tomorrow morning and doing it myself. I've already used a machete on a few smaller branches.
post #6 of 99 Old 02-18-2012, 11:20 PM
odyssey017
Pictures or it didnt happen
odyssey017 is offline
post #7 of 99 Old 02-18-2012, 11:27 PM
BackRoadJPin
1995 Wrangler
Back Road Jeepin
post #8 of 99 Old 02-18-2012, 11:56 PM Thread Starter
SKYOFSCORPIONS
Pictures tomorrow. Really, it was such a stupid spot to get stuck at . I was looking for areas to take good pictures of the scenery. At least it's in a good area where only millionaires live (top of Palos Verdes,CA overlooking LA and the ocean), so I'm pretty sure it's safe overnight.
post #9 of 99 Old 02-19-2012, 12:57 AM
SnowYJ
1988 MJ Comanche
So why are you stuck?
I go to college and I drive a Jeep.
SnowYJ is offline
post #10 of 99 Old 02-19-2012, 01:08 AM
BackRoadJPin
1995 Wrangler
He isn't driving a YJotM , but he could be in the future.
Back Road Jeepin
post #11 of 99 Old 02-19-2012, 01:40 AM Thread Starter
SKYOFSCORPIONS
What's a YJotM?
I'm stuck because I was off-roading just as the sun set (foolish to do), I can't drive up the hill or turn either direction because of 4" branches. So I need to cut them away once there is daylight. The ground is semi-soft there, so I think then lowering the tire pressure may help getting out of that spot.
post #12 of 99 Old 02-19-2012, 01:44 AM Thread Starter
SKYOFSCORPIONS
Worst case scenario, I'll need someone with a winch if removing the branches doesn't work, which I know of no one around here that has a winch
post #13 of 99 Old 02-19-2012, 01:51 AM
BackRoadJPin
1995 Wrangler
Originally Posted by SKYOFSCORPIONS View Post
What's a YJotM?
http://www.jeepforum.com/forum/f12/j...nowyj-1322519/
See my previous post about finding some possible help local. Airing down might be helpful, but all of this information is only going to help so much as none of us have a clue what the true nature of your scenario is or just how stuck the Jeep actually is.
Back Road Jeepin
post #14 of 99 Old 02-19-2012, 05:44 AM
Hghgrad
What sort of tires do you have? Sounds like a couple well placed 2x4's could get you over the branches.
1994 Wrangler...4.0 AW4 swapped, sye'd, 5.5" lift and 33's
Hghgrad is offline
post #15 of 99 Old 02-19-2012, 06:46 AM
BSD
light the branches on fire... wait a few hours, pull the carcus of jeep out.
BSD is offline
jeep just did not want to go up the hill today mylightsrsquare YJ Wrangler Technical Forum 9 12-10-2010 06:01 PM
e-brakes does not want to hold jeep parked on a hill... 0okamiDigital TJ Wrangler Technical Forum 29 10-01-2009 02:22 PM
jeep over heated going up a steep hill boosted_A9 TJ Wrangler Technical Forum 2 04-02-2009 09:00 PM
Could my Jeep tackle a 40 grass hill? FrankGG TJ Wrangler Technical Forum 48 10-05-2007 02:01 PM
gears not holding jeep on hill jeeptj00boy TJ Wrangler Technical Forum 45 04-25-2006 09:06 PM
