Jeep still over heating even after head job - Page 4 - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > YJ Wrangler Technical Forum > Jeep still over heating even after head job
Forever Wave Flags at JeepHutRubicon Express lift kits w/shocks are on sale!ORS4x4: New Product!
Unread 10-05-2007, 08:40 AM   #46
rustywrangler
Got my eye on you.....
rustywrangler's Avatar
Originally Posted by jeepwrnglr92
Where did you get the rad?
I am not sure what t-stat is has. I bought it from Bennett
They said it was a Part master reboxed it was Stant in the box. But not super stant..
I guess I'll go with the 180 first.
Stay at 195* Don't bother with the 180
Congenital Heart Disease is a reality for me, BOTH of my children have it. Please read up and become aware for future generations
Lydia Ann-Acquired 08/05/05 Open Heart surgery 08/10/05
Jacob Patrick-Acquired 01/17/08 Open Heart surgery 02/15/08
rustywrangler is offline   Reply With Quote Quick reply to this message
Unread 10-05-2007, 09:16 AM   #47
bamato
I figured it's about time I entered this thread. I'm no cooling system expert, but I played this same "ball game" with my jeep for the last 6 or so months. Rusty up there can vouch for that.
So judging by all the posts, and all the things you have tried to do, I have what I hope is an answer to your problem. So you have an IR thermo? Perfect. Run the engine till it gets pretty warm and start diagnosing. Measure as many different spots of the block as you can and note ANY hotspots. Measure the exhaust manifold tubes for each cylinder and see if one is hotter/cooler than the other. Also, are you still going through coolant?? Have you retested the block for combustion gasses in the coolant?
If you had the head redone, and its been tested for leaks and passed, then one of the above methods should dhow something. There is probably a good chance that there is a clog in your block. There is one way to find out for sure but it really sucks. And thats to pull the motor and knock out the freeze plugs. That will allow you total access to see if there is blockage in the water jacket. My case ended up costing me a new motor. Hope this helps, Brian
/l , [____],
l---L--?lllllll?-
()_) ()_)----)_)
Mud is your Friend :)
Tread Lightly
Please help keep our trails clean for future generations to enjoy outdoor recreation as well!
bamato is offline   Reply With Quote Quick reply to this message
Unread 10-05-2007, 10:38 AM   #48
jeepwrnglr92
2015 JK Wrangler
Thanx for the ideas. WOW new motor. I just dumped $1200 into this heep engine. For a few more I could have had a v8
So there is no way to unplug a block?
What was wrong with yours that you needed a new engine?
2015 Jeep Wrangler JKU "Tank" Sport S
2002 Avalanche: To many mods to list
jeepwrnglr92 is offline   Reply With Quote Quick reply to this message
Unread 10-05-2007, 10:58 PM   #49
hdfxrs91
1987 YJ Wrangler
I got it from a local radiator shop that had been around for about 30 years. I like to support local businesses when I can.
And I would stick with the 195* t-stat as well.
hdfxrs91 is offline   Reply With Quote Quick reply to this message
Unread 10-06-2007, 08:11 AM   #50
Angelous
1987 YJ Wrangler
I saw this on an XJ. We ended up swapping in a newer style coolant res. For some reason the old one would allow enough pressure to keep it cooled down.
"There is no hole to deep, or mountain to steep, for the driver of this Jeep!"
87 YJ - 2.5 - TJ Flare Swap - Rubicon's - no track bars -
Angelous is offline   Reply With Quote Quick reply to this message
Unread 10-06-2007, 10:39 AM   #51
jeepwrnglr92
2015 JK Wrangler
OK i put the 195 in it and still over heats badly....
Unread 10-06-2007, 11:41 AM   #52
jeepwrnglr92
2015 JK Wrangler
I ran a hose over th rad nad it coold down right away. So I guess I am going to try a new rad. at this point.
Unread 10-06-2007, 04:16 PM   #53
jeepwrnglr92
2015 JK Wrangler
Well new rad and tstat and new temp sending unit.
Still over heats another $250 on the heep down the drain...
Unread 10-06-2007, 05:25 PM   #54
NJeepyj91
Do you have AC? If not, I am thinking it, as others have mentioned, is a water pump issue. Your old pump should have had an R stamped in the casting. As others have said. I think you have the wrong water pump. Mine is a 91 with no AC. It requires a reverse water pump. I hope this helps.
I hate to see you throwing money at it but look at the bright side. You have a lot of spare parts and it is a Jeep thing. You will need all that stuff eventually.
NJeepyj91 is offline   Reply With Quote Quick reply to this message
Unread 10-06-2007, 06:56 PM   #55
jeepwrnglr92
2015 JK Wrangler
I have AC and I don't have the original pump any more. I keep calling the part places they they tell me there is only one pump listed for my engine.
I am thinking that too but none here in SFL seem to know there is another pump.
If anyone knows the part numbers may be I can ref that at ths parts store.
From what i can find out its 91 that has the 2 pumps not a 92. 92 had a reverse flow pump and that all that will bolt up to it.
Unread 10-06-2007, 07:04 PM   #56
NJeepyj91
This is what I have on mine. Your year calls for the same thing. Question? Do you have a serpantine belt?
http://www.quadratec.com/products/51212_58.htm
Unread 10-06-2007, 08:06 PM   #57
jeepwrnglr92
2015 JK Wrangler
Yes I have a serpatine belt. Pepboys and Bennett all ways one pump and advanced auto says one pump Doe snot ask if I have ac or a serp belt etc.
Man that expensive they sell one locally for $38 with a lifetime warrantie.
Unread 10-06-2007, 08:17 PM   #58
ionakana
Grand Poobah
ionakana's Avatar
did you check to see if the coolant was flowing?
try running it without the t-stat in. If it still over heats then the serp belt is routed wrong and spinning the pump backwards or you botched the head job.
Psalm 14:1
http://www.oddhammer.com/tutorials/d...debt_clock.swf
Live in Georgia? click here--> http://georgiacrawlers.com/
ionakana is offline   Reply With Quote Quick reply to this message
Unread 10-06-2007, 08:17 PM   #59
NJeepyj91
You don't have to buy the Flow Kooler. I am pretty certain you need a reverse flowing water pump. And stop stressing that engine.
Unread 10-06-2007, 09:07 PM   #60
1992 renagade
Have you checked the coolant for combustion gases??? A simple test could tell you if you have a leaking head gasket or a possable cracked head. Most shops use a dye that is blue and if it turns green you have combustion gases in the coolant. Also have you tried to burp any air pockets out of the coolant system?
Neill
1992 black Renegade
4.0L 5spd. 4:10 gears 33x12.50 BFG KM 2's A to Z fabrication front and rear bumpers and cage
1994 YJ Sahara Project Bean
2000 Jeep Cherokee Stock
AtoZ Fabrications www.atozfabrication.com
Blue Mountain Jeep Alliance www.bmja.org
Delaware jeep Association www.delawareja.com
Screw the HOA. More guys just need to start doing man things in the garage.
Originally Posted by aw12345 View Post
Jeeps are like mistresses, they take all your money, but boy what a ride!
1992 renagade is offline   Reply With Quote Quick reply to this message
