Jeep still over heating even after head job - Page 2 - JeepForum.com
post #16 of 203 Old 10-02-2007, 05:34 PM
Elf
Just my 2 cents... If it gets hot while sitting, and cools a little while moving, I would take a real good look at the fan clutch... Just my two cents...
Elf is offline
post #17 of 203 Old 10-02-2007, 06:11 PM
cyco
gasket
Originally Posted by cyco
if its not the right head gasket, could be covering water ports, sometimes you can turn the gasket the wrong way, works fine but covers water ports
sorry i mean't to say intake gasket, not sure about 6 cycl, but have seen them wrong on chevy v8 an ford, both over heated fast
cyco is offline
post #18 of 203 Old 10-02-2007, 08:27 PM
tomjohn
Check the temprature at the radiator inlet and outlet. The bottom radiator tank should be 11 to 15 degrease cooler than the top tank. If the drop is more than this the radiator is restricted.
tomjohn is offline
post #19 of 203 Old 10-02-2007, 09:40 PM
monger
was the head machined flat before reinstalling it with a new headgasket? nowhere in any of your posts have you mentioned any machine work. I have actually bought "remanufactured" heads that were not perfectly flat....you cant usually get away with doing a "slip & slide" headgasket job.
monger is offline
post #20 of 203 Old 10-03-2007, 05:45 AM Thread Starter
jeepwrnglr92
2015 JK Wrangler
Sorry never did a head job that they did nto machine it. So I just assumed every one machined theirs. But yes it was machined flat. They said it really did not need it. But they did machine it none the less.
2015 Jeep Wrangler JKU "Tank" Sport S
2002 Avalanche: To many mods to list
jeepwrnglr92 is offline
post #21 of 203 Old 10-03-2007, 05:48 AM Thread Starter
jeepwrnglr92
2015 JK Wrangler
Yes this was replaced 2 times with new fans and still over heats.
post #22 of 203 Old 10-03-2007, 08:03 AM
kamaroman68
Someone already mentioned this and i think hes probably right. If you have a serpentine belt drive you need a reverse rotation water pump. If you have a standard V belt setup you need a regular rotation pump. These are interchangeable physically but will cause your overhaeating issue. I would check that first. Chris
kamaroman68 is offline
post #23 of 203 Old 10-03-2007, 09:01 AM
rustywrangler
Got my eye on you.....
rustywrangler's Avatar
I have to agree with this one. If you did everything you stated, then one of the obvious things I think is the wrong water pump is used. They offer both for that year YJ.
Congenital Heart Disease is a reality for me, BOTH of my children have it. Please read up and become aware for future generations
Lydia Ann-Acquired 08/05/05 Open Heart surgery 08/10/05
Jacob Patrick-Acquired 01/17/08 Open Heart surgery 02/15/08
rustywrangler is offline
post #24 of 203 Old 10-03-2007, 09:04 AM Thread Starter
jeepwrnglr92
2015 JK Wrangler
Well supposidly they have the right one for that engine. I wont know until i get it home and pull it.
Also they did put an electric fan on it to test and its still over heating.
post #25 of 203 Old 10-03-2007, 09:10 AM
rustywrangler
You said you had the rad flushed but what about the block? what you just said tells me a blockage or the wrong water pump.
post #26 of 203 Old 10-03-2007, 09:34 AM Thread Starter
jeepwrnglr92
2015 JK Wrangler
OK just confirmed the part numbers and the pump is for a serp belt. not the v belt.
Man tis i sperplexing. a cooling system has only so many parts...
post #27 of 203 Old 10-03-2007, 09:36 AM Thread Starter
jeepwrnglr92
2015 JK Wrangler
Yes I had the block flushed too. Sorry I did a 2 part flushing. one with rad in the heep and one where we sent the rad out.
I put a hose in the block and used the prestone flush kit.
just an off the wall thought ... what about pulling the upper and lower hoses and putting comressed air in the block? or is there to many place to block up to get a good pressure build up to blow out what ever may be blocking it?
Not sure if that would work or not.
Ya I am reaching at this point...
post #28 of 203 Old 10-03-2007, 09:39 AM
rustywrangler
Ok, then its gotta be the H20 pump. Unless of course you have the tstat in backwards. I wouldn't bother with the compressed air.
post #29 of 203 Old 10-03-2007, 09:59 AM Thread Starter
jeepwrnglr92
2015 JK Wrangler
Well the part place confirmed the H2O pump was the right one so how could it still be that one?
post #30 of 203 Old 10-03-2007, 10:08 AM
rustywrangler
I can get a serp. belt pump in both reverse and forward rotation. I do not know what one you need personally.
jeep over heating at speed emahan01 TJ Wrangler Technical Forum 43 05-04-2009 06:47 PM
Jeep Vs well head ryno121 JK Wrangler Technical Forum 8 04-15-2008 03:10 PM
My Jeep Is Still Over Heating! 03WrnglerSahara YJ Wrangler Technical Forum 25 06-26-2007 12:17 PM
jeep over heating need help bad jeep jake TJ Wrangler Technical Forum 4 08-04-2005 12:34 PM
Over heating Jeep YJ 2.5L cody11ca YJ Wrangler Technical Forum 4 05-23-2005 05:23 AM
