Jeep still over heating even after head job
#1 | |
OK this is getting old really quick
I changed the water pump, tstat fan belts, had the head done and the radiator flushed and tested. What else could it be. THe stupid thing is still over heating. New shroud and new fan/clutch Sorry left that out EDITED TO INCLUDE MORE INFO: Hi All, I decided to clean this post up and be a little clearer on what has been done to the heap to this point. Truck seemed to be running fin when I first bought it. But it was cooler in Jan. I did the basics: Plugs Wirers Oil/filter Air filter {Shock,Brakes,Tirers/rims} Yes no affect on cooling I know, just part of the list Flushed the coolant (block and radiator ) with Prestone kit. Hoses checked ok Changed out tstat Clutch fan Flushed and pressure tested radiator No coolant in oil New water pump Another new tstat New belt Pulled the fuel tank and replace bad hose to fuel pump New radiator cap (x2) Pulled head and had it rebuild and resurfaced Put in new seals, gaskets etc. new fan shroud Some of this I did some the mechanic did so I am going to check his work when it gets home.
For sale 1992 YJ Wrangler: Hurculiner, bestop Safari top.RC 4" lift 32 AT wheels, custom bumpers, 2000 Corvette Roadster: Almost stock http://www.demonoff-road.com/ 2002 Avalanche: To many mods to list Last edited by jeepwrnglr92; 10-02-2007 at 06:25 AM.. |
#2 |
Is the fan clutch working properly? Is the fan shroud intact and installed?
#3 |
Pockets Officially Empty
Always start with the easy stuff before you start throwing money at a problem. As isuace said, check the clutch fan and the shroud. Is your coolant level right, and is the mixture correct? Do you have a winch or lights on the front end that is blocking airflow to the radiator? Is the front of your radiator caked with mud or anything that is preventing it from working? Do you have coolant in the oil? Double check your thermostat and make sure you didn't get a bad one.
2000 Jeep Wrangler Sport 4.0L 5sp 4" Pro Crap lift, 1.25" JKS BL, 1" Brown Dog MML, 35 Maxxis Bighorns, Lock-Right up front & Detroit out back, Super 35, Jeeperman front bumper, Warn XD9000i, Raingler nets, homemade discos, Poison Spyder cage.....In the middle of a re-birth! Yellow Jeep Club Member #66 Colorado Jeep Club Member #66 KUK9's 00 TJ Stretch Build |
#4 |
no winch or mud. have not even been off road with it yet.
![]() Been in the shop all summer. Stock setup. Yup I did replace all the simple stuff first. tested the coolant and had exhaust gases in the coolant. so we did the head still not working. tried 2 tstats etc.
For sale 1992 YJ Wrangler: Hurculiner, bestop Safari top.RC 4" lift 32 AT wheels, custom bumpers, 2000 Corvette Roadster: Almost stock http://www.demonoff-road.com/ 2002 Avalanche: To many mods to list |
#5 |
check the exhaust system. Clogged cat can cause hot gas to back up... clogged muff the same.
1989 Jeep Wrangler YJ- PARTING OUT- http://www.jeepforum.com/forum/f149/89-yj-part-out-862198/ |
#6 |
Grand Poobah
a friend put his belt on wrong and was spining the water pump in the wrong direction causing his to over heat. Is you serp belt on right?
. "Is America ready for a real leader not just a reader?." _ Herman Cain http://www.oddhammer.com/tutorials/debt_clock/US_debt_clock.swf Live in Georgia? click here--> http://georgiacrawlers.com/ |
#7 |
Moab dreamin'
Maybe describing when it overheats will give folks ideas. Does it just go straight to red sitting still, just on the highway, etc? Does it redline or just run hotter than it should?
'98 TJ (see profile) '88 YJ with 4.0/AW4 swap & CJ front end '97 XJ 4.0/aw4/3.5" lift/33x10.5 BFG ATs '80s CJ Resto-mod ('80s CJ frame/front end, YJ tub, '00 XJ 4.0) |
#8 |
I am hoping the mechanic put the belt on right. It was on right when I gave it to him
as for what is happening I had another threat on this a while back but here goes. At idle the truck temp goes up to 240+. It does not take long for it to get there. When I start driving it "use" to go down in temp but who knows at this point what it is doing.
#9 |
Just a thought, have you considered hoses? A friend of mine reused some radiator hoses on a s10 after replacing everything else and whenever the engine would reach a certain temperature, the walls of the hose were so weak they'd collapse on themselves and starve the engine. It took him weaks to figure it out.
#10 | |
I did check the hoses when it was up to temp and they seemd ok. but at this rat I may try replacing them,
#11 |
Did you check your temp sensor to see if it is good and really reaching these temps?
93 YJ SOA 2" springs front, XJ springs rear w/main leaf added, High pinon 9 inch rear detroit locker front Dana 44 ARB 4.56 Gears, 36 inch Irok tires too much to list. www.mijc.org |
#12 | |
The mechanic said he used a IR thermometer gage and it was reading high. I thought the same thing and I may replace it once it gets home just to be safe I think its only 16$ or something like that. I bought an IR thermometer too and Ill check it with that too.
#13 |
if its not the right head gasket, could be covering water ports, sometimes you can turn the gasket the wrong way, works fine but covers water ports
#14 |
I believe that there are some engines where the water pump turns in one direction and other engines it turns in another direction. When purchasing a new water pump, you have to make sure that the vanes are facing the same direction as the original.
One way to make sure that coolant is moving through the system is to remove the t-stat and watch the water through the rad cap to see if it is moving in the right direction. Also make sure you have the proper temp t-stat (195). |
#15 | |
I am not running a cat just a muffler and it seems to be flowing OK. Not sure how you check that except that there is good flow out the back.
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
