Jeep is stalling! I have no idea why - JeepForum.com
post #1 of 7 Old 01-16-2009, 04:52 PM Thread Starter
Renegade 91
Lately i have been driving around in my YJ. and when I would come to a stop then give it a little gas to start moving the rpms would drop down, then go back up. It didn't seem like such a big deal. But now my jeep will stall out instead of the rpms going back up! The jeep will also always start back up after about 5 or 10 minutes. Im taking it to a mechanic monday, but i would like to get an idea what is happening.
Renegade 91 is offline
post #2 of 7 Old 01-16-2009, 11:05 PM
NEVER-ENOUGH
Just a question. Have you "Seafoam'd" it?
NEVER-ENOUGH is offline
post #3 of 7 Old 01-17-2009, 10:42 AM Thread Starter
Renegade 91
what does that mean?
post #4 of 7 Old 01-17-2009, 07:31 PM
bob082484
Its got a 4.0. I dont think they came with carbs.
bob082484 is offline
post #5 of 7 Old 01-17-2009, 08:57 PM
Bomac66
Try some dry gas if you haven't already. If it just started doing this lately you might have ice build up.
Bomac66 is offline
post #6 of 7 Old 01-17-2009, 10:11 PM
Alexsdad
Don't know much about the 4.0...but is sounds like your Idle Air Control valve has taken a large dump.
My Son's Wrangler (I wrench it)
1994 2.5L AX-5
Alexsdad is offline
post #7 of 7 Old 01-17-2009, 10:18 PM
Absolutexero
as a mechanic myself, i'd venture to say it could be a couple of things, IAC/TPS is most likely, if you've replaced those check your fuel filter (not sure if it's serviceable, mine is not), i've seen cars that crank and run fine until they get warm, die, and you can't crank them for an hour or so just due to the fuel filter putting too much strain on the fuel pump. If that doesn't do it, I may be able to help you if you can provide a little more info (what have you replaced recently, et al)
"Don't ask questions you don't know the answer to."
Absolutexero is offline
stalling jeep... Anonymous6915 YJ Wrangler Technical Forum 5 10-28-2009 05:42 PM
jeep stalling M 88 YJ YJ Wrangler Technical Forum 13 11-25-2008 07:38 PM
jeep stalling mtwallace14 YJ Wrangler Technical Forum 7 03-07-2007 09:52 PM
Jeep Stalling RmK YJ Wrangler Technical Forum 1 08-24-2006 01:49 AM
jeep still stalling XTC Jpr13 TJ Wrangler Technical Forum 12 11-30-2005 06:30 PM
