Jeep stalling and cutting out. - JeepForum.com
post #1 of 12 Old 11-13-2014, 05:42 PM Thread Starter
coseph
Jeep 95 yj, 2.5 L, 5 spd.
I recently moved from Southern Illinois to Green River, Wyoming. It is -20 here and 6200 feet above sea level. A big change from where I'm from. This information may be important or not.
Ok, jeep starts every time when it has sat for hours, when I give it gas in neutral or in gear it begins to stall (choppy) unless I apply more than normal throttle. When I barely apply any gas at all it stalls. When shifting gears it will stall unless I apply more than normal gas. The biggest issue is that once it stalls after initial ignition it will not start again for hours. I haven't checked fuel pressure yet due to the local stores not loaning tools. I don't believe spark to be the problem but y'all are smarter than me. I've read to replace the TPS and I've been told to replace the MAP sensor. First things first I am going to test the fuel rail and replace fuel filter, add some Heet.
I'm not extremely mechanically inclined and I am always a little intimidated by working on vehicles so have some patience with me. Anyways, given these symptoms do you guys think I'm on the right track and do you have any suggestions?
coseph is offline
post #2 of 12 Old 11-13-2014, 06:46 PM
laybackman
Bikini Bridge Inspector
laybackman's Avatar
2010 JK Wrangler
With a cold engine: Take the + battery cable off of the battery. Ground the end of that cable for 30 seconds or so. Stick that + battery cable back on the battery. Start it up and drive it until it gets completely warmed up. That might fix it. I had you dump the learned memory in the brain. You have a big change in atmospheric conditions and your air/fuel mix and possibly your timing was probably wrong for your new climate and height above sea level.
Do you know what was good about the good old days? I wasn't good, And I wasn't old!
Senators and Congressman should wear uniforms like NASCAR drivers so we could identify their corporate sponsors....
laybackman is offline
post #3 of 12 Old 11-13-2014, 06:51 PM
mike134
Clean the throttle body and IAC. Then search for vacuum leaks by spraying carb cleaner on all the vacuum lines.
mike134 is offline
post #4 of 12 Old 11-13-2014, 08:25 PM Thread Starter
coseph
Alright thank you all for the tips!
coseph is offline
post #5 of 12 Old 11-16-2014, 04:37 PM
mike134
Actually, do the vacuum leak tests first. I bet a hose cracked in the cold.
mike134 is offline
post #6 of 12 Old 12-07-2014, 08:12 PM Thread Starter
coseph
Okay, so I've replaced the fuel filter and someone recommended that I run BG 44k through it to clean the injectors as they believed that to be the problem. It just occurred to me that I am missing a vacuum hose that runs from the fuel regulator to the intake manifold. Though, I am not sure where the hose goes into the intake manifold. Does anyone know if this could be the problem and if so do you have a picture of where it goes into the manifold. I drove the jeep 300 miles today and the cutting out was gone until the jeep sat for an hour. It seems to be worse as the temperatures go cold… I'm not sure where ever vacuum hose is, so I haven't tested for leaks yet.
coseph is offline
post #7 of 12 Old 12-08-2014, 02:08 AM
laybackman
laybackman's Avatar
2010 JK Wrangler
Here you go!
post #8 of 12 Old 12-10-2014, 01:06 PM Thread Starter
coseph
I've checked it and there is no open spots on the intake manifold so I've got my vacuum hoses mixed up somewhere. It seems the spot w her the fuel regulator should plug into the intske manifold is plugged into a cylinder that is on the lower drivers side of the engine bay. Ill look up an intake manifold vacuum hose diagram
coseph is offline
post #9 of 12 Old 12-10-2014, 01:30 PM
mike134
Might be a good idea to check over all vacuum hoses, but I think some of them are supposed to have Tee type splitters. So a couple hoses coming from one port.
mike134 is offline
post #10 of 12 Old 12-10-2014, 06:26 PM Thread Starter
coseph
I cant find good schematics or pictures. Just need to find a YJ and look lol. Anyone wanna post me a picture or pictures of there 2.5s manifold hoses ?
coseph is offline
post #11 of 12 Old 01-13-2015, 07:19 PM Thread Starter
coseph
Can anyone with a 2.5 L post some pictures of the vacuum lines from and to the intake manifold? And the hose that runs to the MAP sensor.
coseph is offline
post #12 of 12 Old 01-13-2015, 07:53 PM
laybackman
laybackman's Avatar
2010 JK Wrangler
This is a diagram but it is fairly straight forward;
stalling
