Jeep sputtering when cold - JeepForum.com
post #1 of 3 Old 02-05-2002, 03:01 PM Thread Starter
FishWagon
Hello all,
My 88 Wrangler 4.2 has a problem. When engine is cold, I get really bad sputtering at about 2k rpm, and black smoke coming out of the exhaust.
When engine warms up, problem goes away, and engine runs fine.
I figured this is carb related, but could it be the O2 sensor also? The carb is brand new, but could something be holding the choke in the wrong position? I just finished giving the engine a full tune-up.
Thanks!!
FishWagon
88 Wrangler 4.2 5spd
33X11.50's, 3" lift.
Many exterior mods..
FishWagon is offline
post #2 of 3 Old 02-05-2002, 04:26 PM
Bob K
Bob K's Avatar
Yes, sounds like the choke is running too rich during warm-up. If the coil spring is not adjustable you might be able to adjust it by bending the arm. I recommend the JuiceBox ignition system to anyone with a pre-'91 YJ or CJ. Best $130 you could ever spend on your Jeep.
'87 Wrangler YJ 4.2 I6 (sorry, sold)
JuiceBox ignition
2 1/2" ProComp Lift
31" BFG A/T's
K&N Filter
Custom Rock Guards
Turbo Muffler
Rear Track Bar in the shed
Other Tricks I won't tell to just anybody!
'99 Grand Cherokee 4.7 V8
Towing Package
K&N FIPK
ProComp MX6 shocks
Borla Exhaust
Tow Hooks
Alpine CD with Infinity+iPod connect
Just getting started!
If you're not living on the edge...
you're taking up too much space.
Bob K is offline
post #3 of 3 Old 02-05-2002, 10:49 PM
Johnny'sJeepen
I have the same problem with MY 89 YJ. I was thinking about the juicebox. Do you happen to have a picture of it? Are there different models that i should be aware of?? Any advice would be great.
Thanks
J
Johnny'sJeepen is offline
rough cold starts, and sputtering at 1/4 throttle lancer27 YJ Wrangler Technical Forum 0 01-02-2010 09:34 PM
Sputtering Jeep grinwa TJ Wrangler Technical Forum 1 09-16-2009 07:14 PM
sputtering when cold emilior TJ Wrangler Technical Forum 1 09-08-2007 04:10 PM
WARM starting/ sputtering when cold jeepcj7 TJ Wrangler Technical Forum 3 05-25-2007 02:55 PM
Jeep Sputtering eastwood1972 TJ Wrangler Technical Forum 4 10-25-2004 07:55 PM
