Quantcast jeep sputtering and stalling - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > YJ Wrangler Technical Forum > jeep sputtering and stalling
Old 03-11-2007, 07:29 PM   #1
kenny kustom
My Jepp has been doing some weird stuff lately. Once ans a while it will just sputter and high idle or sputter and stall. It has stalled when driving a few times too. Crank and crank. Wait a while and it will fire right up fine.. Over the weekend I installed the FirePower Performance Ignition. Fired up great and smooth. But it's still doing it. I can hear the fuel pump comming on. I am going to try fuel filter tomorrow. After that, im thinking pump. QUESTION : Do i replace the internal with another, or go with a outboard frame mounted pump ? Or is it something else ?
1989 yj. AMC 360, Cj front clip and custom interior/dash. Herculiner inside and out, Dana 60's, 5.38's, ARB's. 40" iroks.
2008 JK Rubicon Unlimited.
kenny kustom is offline   Reply With Quote
Old 03-11-2007, 08:00 PM   #2
Raindem
I think you're on the right track. Sputtering as you describe it is usually a fuel delivery issue. Make sure all your lines and fittings are in good shape.
If it ain't broke... break it.
Raindem is offline   Reply With Quote
Old 03-12-2007, 07:04 AM   #3
kenny kustom
Going to attach fuel pressure guage to the rail this morning, and check the pressure when idleing
Old 03-14-2007, 12:31 PM   #4
kenny kustom
solved !!!!!!!!! My crank sensor had melted against the exhaust downpipe. One of the wires was shorting out.
Old 03-14-2007, 12:36 PM   #5
TravisR
sorry... whats a crank sensor???
90 yj project
TravisR is offline   Reply With Quote
Glock Forum
