Jeep spraying gas at intersection - JeepForum.com
post #1 of 14 Old 06-30-2011, 04:16 PM Thread Starter
CaptAmerica219
Rough day. Sitting a traffic light w/ a 9 year old in the back. My doors are off and I could barely smell some gas fumes but didn't think much of it. Then a truck full of landscapers roll down their window to tell me, "Hey, is that water spraying out of the back?" Nope, not water. From my driver's side rear wheel well is gasoline spraying everywhere.
Long story short, I clearly have a problem with one of the pressurized hoses in my fuel system. From what I have read, it sounds like it could be the return line. The NAPA guy basically told me that NAPA doesn't carry anything that can help me and the dealership might not either. Does anyone have any ideas as to what it could be (more specifically) and where I can get the hoses?
CaptAmerica219 is offline
post #2 of 14 Old 06-30-2011, 04:32 PM
bikerdude
1987 YJ Wrangler
They must have been looking for premade hoses like some vehicles have. I just bought bulk high pressure fuel line at Advance Auto. I think it was 3/8" and I got about 6 feet and had some left over. The lines run through a grommet in a crossmember ahead of the tank and I couldn't get the old lines out so I rerouted the new ones around the crossmember and made sure they were safely routed. If it is "spraying" it is probably the pressure line. I would replace both.
bikerdude is offline
post #3 of 14 Old 06-30-2011, 04:36 PM Thread Starter
CaptAmerica219
Are both hoses the same diameter? I was under the impression that one was 3/8 and another was 5/8.
post #4 of 14 Old 06-30-2011, 04:51 PM
bikerdude
1987 YJ Wrangler
It's been a while and I am getting forgetful, almost certain the pressure line is 3/8" but the return could be 5/16" but not 5/8". The front end of them connect ahead of the tank so you can check by crawling under and looking before dropping the tank. Maybe someone else knows the size offhand.
post #5 of 14 Old 06-30-2011, 05:45 PM Thread Starter
CaptAmerica219
Appreciate the help Bikerdude.
post #6 of 14 Old 06-30-2011, 08:02 PM
50rck
Yes, you can buy them in bulk from just about any autoparts store. I replaced all of my rubber hoses 2 years ago, and I think I used a whopping 8 feet total between the 2, with some left over. Just make sure it is FOR FUEL INJECTION ONLY. Those lines are under a lot of pressure, and the fuel injected lines are stronger than the standard fuel lines that are used to feed the carbs.
1991 YJ, rebuilt 4.0L in spring 2009 at 234,000 miles, no lift yet, slightly offset wheels, 235/75/15 tires for now, rag top, sold the hard top. Over 35,000 miles on the rebuild and counting.
2006 Jeep Liberty. Nothing special, all stock.
50rck is offline
post #7 of 14 Old 06-30-2011, 08:20 PM
Louie4
My money is on the fuel filter. Those hoses that connect it to the hard lines. IIRC I got some standard 5/16" fuel hose and replaced the old cracked ones. There is one that is bent at 90 degrees but I was still able to use just standard fuel line.
Lou
YJOTM July 2012
YJOTM February 2014
Louie4 is offline
post #8 of 14 Old 06-30-2011, 09:32 PM
monkeyhouse
Your napa guys sucks man. I walked into napa and had a piece of fuel hose and said you have anything I can replace this with, he pointed to a spool on the wall and said how much you need?
First Jeep was an 1989 YJ, 6 cylinder 4.2L , 258. Nuttered and TeamRushed, Weber 38 DGES, Now, I'm venturing into the world of Grand Cherokees
monkeyhouse is offline
post #9 of 14 Old 06-30-2011, 10:32 PM
firefighter315
with this ^^^. I've had it happen on my '94. It sprayed like a garden hose with a hole in it. I've used the same fix Louie did, but made sure to clamp it down well. the hard line is a slightly different diameter than the tank side of the filter connection. Leave enough slack that the hose doesn't kink at the 90 deg. turn. I put an extra hose clamp right in the bend to help keep the hose round and help keep it from kinking. (I hope)
My YJ Build Thread
firefighter315 is offline
post #10 of 14 Old 07-01-2011, 09:27 AM
jmmorgan82
2009 JK Wrangler
Mine was doing the same thing and somehow one of the clamps had come loose and walked-off the hose and another clamp was loose. 30 seconds with a flathead screwdriver and she was good to go.
jmmorgan82 is offline
post #11 of 14 Old 07-01-2011, 09:33 AM
pasinbuy
There may be a few reasons for the gas leak.
1) The rubber gasket for your sending unit has disintegrated. Possibly dealer only part, and there was a recall on it, if it is still active I do not know.
2) The fuel line to the fuel pump has cracked. There are two. One of the lines is a dealer only part because one end is larger than the other end. You can force a new hose on but you will eventually have another problem. Buy the right hose.
3) There is a 90 degree piece of hose just before your fuel filter that has cracked. This is also a dealer only part although I have heard of some placing a tube into a piece of hose to make the 90 degree piece. My advise is, Buy the right hose.
I know about all three because they happened to me. If I was you I would replace all three the right way so that it does not become another problem later. Ask me how I know this? Now everything is new.
pasinbuy is offline
post #12 of 14 Old 07-01-2011, 09:36 AM
mylightsrsquare
my one fuel hose broke, it was pouring out gas when i went up a steep hill and was dripping pretty fast when parked. i found the hose i needed on ebay for like $20
1988 yj. 4.2l with a Weber and an ax15 swapped in
mylightsrsquare is offline
post #13 of 14 Old 07-01-2011, 10:24 AM
stroked250
Common for the hard lines to seperate from the soft lines near the gas tank. Add a screw tight clamp on it if needed.
stroked250 is offline
post #14 of 14 Old 07-01-2011, 06:59 PM
dodger889
Use the right clamps to make sure that they are designed for the FI line. Yes there is a difference the edge is rounded just a bit to keep from tearing the hose.
A 89 yj with a 4.0 aw4 sye out of an 92xj. Now the hard part is done time to get it up in the air just a bit. Working on 8.8 with 3.73 and lsd for the rear. and new D30 hp with 3.73 .
For those who have not figured this out I'm old school but can handle the new too.
Originally Posted by bigsquat View Post
im just cheap, and cheap makes you creative.
dodger889 is offline
Spraying engine bay JAYCEE1 Wrangler General Discussion 14 05-20-2011 04:32 PM
Oil Spraying SteveJcoYJ YJ Wrangler Technical Forum 10 07-28-2007 01:31 PM
Spraying on Herculiner UTmike TJ Wrangler Technical Forum 16 01-04-2007 12:29 PM
JEEP 2.5 stalls after less than a minute or idling or driving, fuel stops spraying Big-n-Broke-YJ YJ Wrangler Technical Forum 26 02-24-2006 07:13 AM
Oil Spraying Out of Dip Stick? BigTal YJ Wrangler Technical Forum 9 08-02-2005 08:52 PM
