jeep speedo gear - JeepForum.com
post #1 of 1 Old 09-06-2011, 11:00 AM Thread Starter
SFJeep89
jeep speedo gear
It first started when a did the sye. It didn't work at all. But after messing with it four a few hours a finally found the right position for it to work. Afterwards it worked great for about two weeks till I noticed my speed was 20mph then 45mph then 0mph then back to 40mph. I figured it was maybe broken teeth from messing with it so much. I pulled out the speed gear and both the gear and the piece is rides on looked fine. My question tho is the gear itself supposed to pull up and down. It moves up and down about a 1/8 in and is sorta hard to turn. Is it supposed to do that?
SFJeep89 is offline
Take a speedo gear <> Leave a speedo gear spokanistan TJ Wrangler Technical Forum 1399 08-09-2017 09:19 AM
bigger tires, the right gear ratio vs. speedo gear krafalco YJ Wrangler Technical Forum 3 08-16-2011 06:58 PM
Changed speedo gear-Now Speedo no worky BoatCop TJ Wrangler Technical Forum 7 08-07-2011 04:37 PM
Will speedo gear specified for Dodge/Jeep work in TJ? AlexGeorgakis TJ Wrangler Technical Forum 5 07-09-2010 02:56 AM
2?'s Which speedo gear and actual gear ratio maxum3300 TJ Wrangler Technical Forum 6 01-15-2010 06:40 AM
