jeep smells as gasoline - JeepForum.com
post #1 of 13 Old 08-05-2009, 06:11 PM Thread Starter
metalroses
what this could be? i cant drive like this it keeps me worried XD help plz
metalroses is offline
post #2 of 13 Old 08-05-2009, 06:18 PM
jbolty
jbolty's Avatar
where is it coming from?
could be the rollover valve, up inside the right rear fender
could be the gasket where the gauge sender goes into the top of the tank
or, could be any of the soft lines with a crack (or a hard line)
jbolty is offline
post #3 of 13 Old 08-05-2009, 07:03 PM
intenseblu
1987 YJ Wrangler
fuel system stretches across the entire truck ... so start at one end and work your way across.
mine was leaking at the point the fule lines attached to the throttle body (2.5 TBI unit) ...
intenseblu is offline
post #4 of 13 Old 08-05-2009, 07:07 PM Thread Starter
metalroses
mines not leaking as i see the and i cant really tell where is it coming from but it smell outside and inside the jeep
post #5 of 13 Old 08-05-2009, 07:10 PM
idaholtby
Also check to see if your fuel evap canister is hooked up. If it is not, fuel vapors escape to atmosphere.
idaholtby is offline
post #6 of 13 Old 08-05-2009, 07:13 PM
pasinbuy
It is a good idea to fix it right away.
Is the gas odor coming from the front of your YJ or the rear?
pasinbuy is offline
post #7 of 13 Old 08-05-2009, 07:28 PM
Fhajad
My problem was one of my spark plug wires wasn't doing anything, so I had a 6 cylinder just getting gas but no ignition so that was my issue.
Fhajad is offline
post #8 of 13 Old 08-05-2009, 07:31 PM Thread Starter
metalroses
@ pasinbuy. cant really tell where from i can stand everywhere and the odor is there inside the jeep the odor is more strong and i already have new spark plugs last week changed them
post #9 of 13 Old 08-05-2009, 07:46 PM
havasu
On permanent vacation
havasu's Avatar
Mine was located on top of the tank, and would just puddle, making it nearly impossible to find without dropping the tank.
havasu is offline
post #10 of 13 Old 08-05-2009, 08:18 PM
I8AHUMR
My jeep had a bad fuel odor outside, sometimes inside, and it turned out to be the gasket between the fuel tank and the fuel sending unit that is inside the tank. There was a factory recall on it back in the day. Some people have said the dealer will change it still but I went ahead and did it myself. The gasket is is $15. If it's strong in the rear this could very well be it. It's a known problem. You have to drop the tank and swap out the gasket. It's not a difficult task.
93 YJ, 4.0, 4.5" suspension, 33x13.5 Pitbull Rockers, Custom scratch and dent job...
05 WK, 5.7 Hemi, Quadra-Drive II
I8AHUMR is offline
post #11 of 13 Old 08-05-2009, 08:40 PM
cwatson
check your shifter boot mine was loose and I smelled like gas every time I drove
Its mine, I'll break it soon enough so I should go ahead and break it now so I can fix it.....then repeat over and over
cwatson is offline
post #12 of 13 Old 08-06-2009, 12:32 PM Thread Starter
metalroses
ok ill check those things. as you see ive got my jeep 2 years ago and now that i have money im trying to rebuild it thanks for the help
post #13 of 13 Old 08-06-2009, 01:48 PM
pasinbuy
Push it outside.
open your doors to air it out a while.
then do the sniff test.
Feel around the cold motor and trace you fuel lines all the way back to your tank looking for wet fuel on your hands.
pasinbuy is offline
My jeep interior is wet and smells ? chaznad TJ Wrangler Technical Forum 10 07-02-2009 05:29 PM
How to eliminate smells from the Jeep MB98XJ TJ Wrangler Technical Forum 29 01-10-2009 10:42 PM
Jeep still smells hot months after SYE install 01amberfirewv TJ Wrangler Technical Forum 7 12-25-2006 09:42 AM
smells like gasoline k17trojan TJ Wrangler Technical Forum 1 09-21-2004 10:57 PM
my jeep smells zuck2001 YJ Wrangler Technical Forum 13 10-26-2001 02:03 PM
