Jeep shuts off while I'm driving - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > YJ Wrangler Technical Forum > Jeep shuts off while I'm driving
Introducing MONSTALINERô UV Permanent DIY Roll On Bed LineCHASSIS SAVERô Labor Day 2 for 1 Sale!!!JKS Flex Connect in Actions!
Unread 02-13-2013, 03:10 PM   #1
dturner4
I have no idea why this would be happening. Any information would be greatly appreciated. Thank you.
dturner4 is offline   Reply With Quote Quick reply to this message
Unread 02-13-2013, 04:32 PM   #2
Mark05059
does it start back up right off or does it have to sit?
1998 ZJ 5.2 Auto
1989 Wrangler Black Bone Stock 2.5l 5spd
/l , [____],
|---L--[]lllllll[]-
()_) ()_)==O=)_)
Mark05059 is offline   Reply With Quote Quick reply to this message
Unread 02-13-2013, 04:44 PM   #3
kloppk
A classic problem with the 4.2's ignition system is the Ignition Module is getting flakey.
My 89 did the same thing. Driving along and the engine stop like someone turned the key off.
Wait a couple of minutes and it starts up again. Popped a new one in, problem solved.
Baystate Jeepers
Deep Woods Extreme
New England 4 Wheelers
kloppk is offline   Reply With Quote Quick reply to this message
Unread 02-13-2013, 05:15 PM   #4
timatoe
timatoe's Avatar
Yup, 99% chance it's the ICM.
timatoe is offline   Reply With Quote Quick reply to this message
Unread 02-13-2013, 05:28 PM   #5
BlackGallagher
Yep, ICM. I drove my 4.2 '89 off the lot a couple months ago and on the way home it turned off on the highway lol. Only did it that one time, but about a month later the ICM completely stopped working, so get it checked out or replaced very soon if possible.
BlackGallagher is offline   Reply With Quote Quick reply to this message
Unread 02-13-2013, 07:14 PM   #6
tdewit
Had the same. Found the connector between the tub and fuel tank corroded, so I'd run out of fuel. Replace plug and, viola, no more issues.
tdewit is offline   Reply With Quote Quick reply to this message
Unread 02-13-2013, 07:52 PM   #7
7xes
Mine did that with the Fuel pump connector being loose. I replaced the fuel pump, to further determine it was the connector.
7xes is offline   Reply With Quote Quick reply to this message
Unread 02-13-2013, 10:50 PM   #8
timatoe
timatoe's Avatar
The 4.2 has a mechanical fuel pump on the engine.
Unread 02-13-2013, 11:23 PM   #9
kgb_m3
ICM from Autozone works great. Most likely your problem like mentioned above.
89 YJ 4.2L http://www.jeepforum.com/forum/f12/kgb-89-yj-storyline-build-thread-1520814/
96 XJ 4.0L http://www.jeepforum.com/forum/f177/600-96-xj-budget-daily-overland-build-1855418/
http://www.jeepsunclassified.com
kgb_m3 is offline   Reply With Quote Quick reply to this message
Unread 02-14-2013, 08:49 AM   #10
dturner4
Thank you guys for the information. I'll get it switched out and let you know if the problem has been solved.
Unread 02-14-2013, 09:37 AM   #11
dturner4
It starts back up. It almost didn't start back up yesterday though. It took a few times but it started back up.
