Jeep shuts off while driving, HELP PLEASE! Huge mystery! - Page 7 - JeepForum.com
post #91 of 93 Old 03-13-2014, 08:34 PM
sccarr54
1995 XJ Cherokee
HELP I have a big problem with my 95 Jeep XJ
Hey guys, I'm new on here not sure how this works but here I go. I'm having a problem. I have a 95 jeep cherokee xj. So here's the problem. I have crank/no start sometimes and sometimes it will run for awhile then stall. I have replaced the CPS,coil,wires,cap,rotor and spark plugs. I still had the same problem so I went and got the PCM/CMU and put it in. Now it will run for a minute and then stall again. Can anyone help me!!!! PLEASE!!!!
sccarr54 is offline
post #92 of 93 Old 03-13-2014, 10:47 PM
Opihi59
from here it gets rough
Opihi59's Avatar
I can see you've tried to do some research into your problem; it appears unique enough that you should start a brand new thread for this, and I am sure you will get a lot of help.
Welcome to the forum.
....I'm not smart, but I can lift heavy things.......
Fill out your PROFILE, and don't forget to look in the FAQ for writeups
I'm stuck on da Rock
Originally Posted by Brian4.2 View Post
We will be going Metric every inch of the way.
Originally Posted by 40dog View Post
yes I'm a some guy and have always put gasket sealer on my surfaces before mating
Originally Posted by Virjeep View Post
You should go to Pirate. I hear they are real smart over there. You'd fit right in.
Opihi59 is offline
post #93 of 93 Old 03-14-2014, 07:26 AM
Que89YJ
Sccarr it is usually the crank position sensor. Check your fault codes. See what diagnostics gives you.
Que89YJ is offline
radio shuts off while driving incagoldjeep TJ Wrangler Technical Forum 9 07-24-2009 09:15 PM
Huge Jeep mystery WindyCityGuy TJ Wrangler Technical Forum 43 07-22-2008 02:02 AM
88 jeep shuts off Toocrazy2care38 YJ Wrangler Technical Forum 9 06-18-2008 09:25 PM
Help! Jeep just shuts off when driving. Crymsun YJ Wrangler Technical Forum 4 09-17-2004 12:14 PM
engine shuts down while driving jamesscott YJ Wrangler Technical Forum 5 02-03-2002 01:13 PM
