Jeep shuts off after turning off AC? - JeepForum.com
post #1 of 4 Old 08-16-2017, 09:26 AM Thread Starter
tropicalYJ
It doesnt do it all the time but sometimes when I turn the AC off, the Jeep dies. It starts right up again after. Haven't seen any posts regarding this issue so I assume it isn't too common. Any possible issues here?
tropicalYJ is offline
post #2 of 4 Old 08-16-2017, 10:25 AM
jbolty
jbolty's Avatar
Probably the idle dropping too far or too quickly for the fuel/air delivery to keep up.
year and engine would help.
jbolty is offline
post #3 of 4 Old 08-16-2017, 11:28 AM Thread Starter
tropicalYJ
Originally Posted by jbolty View Post
probably the idle dropping to far or too quickly for the fuel/air delivery to keep up.
Year and engine would help.
1993 4.0l
post #4 of 4 Old 08-16-2017, 12:59 PM
Luuca
Typical /f12 Hooligan
Luuca's Avatar
I'm guessing this happens only at idle, not while under load on the street or trails.
If yes, only at idle, you are looking at an Idle Air Sensor issue. It controls how much air to add to keep the Jeep idling.
Remove yours following the Field Service Manual you own, and clean it using Throttle Body cleaner (NOT BRAKE CLEANER) and also clean the throttle body hole for the sensor. If that cures it, you are done. If not, new IAS may be in order.
91 YJ "Alice" 4.0L, AX-15, NP 231 Flange, Adams Driveshafts F/R, 2.5" OME 36Rs, 5/8" /f12 Booms, 33" Yoko ATs, 4.10 D30/35 Aussie Lockers F/R
YJOTM never
05 LJ Rubicon "Ghost"
Luck Favours The Prepared
Luuca is offline
