jeep problem question? - JeepForum.com
post #1 of 5 Old 04-08-2010, 12:11 AM Thread Starter
sifuentesjeeps
2.5 liter, 4 cylinder, tune up about a year ago haven't changed fuel filter though. ok so the battery died today, i dont know why i died. i think it has to do with a kill switch. the last owner of the jeep installed a kill switch but it only turns on when it wants to turn on and when it turns on the lights start blinking on and off and the battery dies. does anyone know how to turn the kill switch off or make it work right, also right when i turned on the jeep there was a really loud screening noise and it started to shake as if it wanted to turn off. any ideas on what the problem might be.
SIFUENTES
sifuentesjeeps is offline
post #2 of 5 Old 04-08-2010, 12:20 AM
moonshinefuel
Sounds like a car alarm was installed and was never taken out completely.
moonshinefuel is offline
post #3 of 5 Old 04-08-2010, 05:59 AM
Que89YJ
X2 Youve got a car alarm you need to find and remove.
Que89YJ is offline
post #4 of 5 Old 04-08-2010, 01:41 PM Thread Starter
sifuentesjeeps
ok how do i take it out and find it
SIFUENTES
post #5 of 5 Old 04-08-2010, 01:50 PM
mfalik
mfalik's Avatar
My Cherokee had a car alarm installed by the PO, and I had to remove it. Without knowing the alarm and how it was installed, here is how I would go about removing it:
First.
Find the alarm control box (look under the dash on both driver and passenger side).
Second.
Once the alarm control box is located, trace all the wires from the box and disconnect them. There may be a couples of wires that are spliced into the factory harness (spliced into the ignition wire), reconnect those wires.
That should do it.
MichiganTech Mechanical Engineer Alumni
1994 Wrangler Sahara - Jeep Project
2003 Dodge Ram 1500 (new truck)
2007 Mazda CX-7 (the new commuter car)
2005 Mitsubishi Lancer (Rear Ended - TOTALED)
1998 VW Beetle (SOLD)
1988 Jeep Cherokee Limited - (SOLD)
mfalik is offline
jeep problem question? sifuentesjeeps YJ Wrangler Technical Forum 1 04-08-2010 06:30 AM
BL problem/question muddy8jeep8 TJ Wrangler Technical Forum 2 01-21-2009 01:34 PM
1 problem, 1 question doubleup TJ Wrangler Technical Forum 5 08-06-2008 11:30 AM
Brake Fluid problem or Jeep Drinking problem daledaniel TJ Wrangler Technical Forum 6 01-04-2008 10:11 PM
4wd problem/question waterlogged TJ Wrangler Technical Forum 4 09-30-2005 09:03 PM
