Jeep Problem...Need good Mechanic - JeepForum.com
post #1 of 5 Old 06-25-2001, 02:10 PM Thread Starter
trixy
I have an 88-jeep wrangler (auto mechanic transmission). I started have carburetor problems in 98. Last year I was told I needed a new engine because of blow-by. My father has fixed that problem, but now the jeep is starting to over heat. I need some help, does anyone know of a good jeep mechanic in the central NJ area.
Thank you,
Trixy : )
trixy is offline
post #2 of 5 Old 06-25-2001, 03:59 PM
gosling1
gosling1's Avatar
Hae you check the radiator or the thermostat? Are you loosing coolant anywhere? The radiator may be clogged and need either flushing or cleaned out.
2.5" Lift, no track bar, no sway bars, dual K&N filters, custom exhaust stack, custom front and rear bumpers, welded front and rear
Tango Uniform
gosling1 is offline
post #3 of 5 Old 06-26-2001, 12:33 AM
solid
If it overheats during stop and go traffic or during idle, then that means not enough air is passing through the radiator...check the fan. If it overheats during high speeds, then it could be blocked coolant passages, etc...
solid is offline
post #4 of 5 Old 09-10-2001, 05:50 PM
B2hi
Check Fan clutch or thermostat.
87 Wrangler 4.2
Mopar MPI
4.0 Head
Throttle body spacer
K+N air filter
Con-ferr shackles,R.E. 4.5 lift with 33x12.5 BFG Muds and 1in. body
B2hi is offline
post #5 of 5 Old 09-14-2001, 10:18 PM
DASLUFOOT@AOL.COM
I see that your dad has fixed the blow-by problem, so he must have rebuilt the engine. Assuming he put a new thermostat in it and it did not run hot before, my best guess would be to check your timing. (Does it feel sluggish?)
DASLUFOOT@AOL.COM is offline
Good Jeep Mechanic or Shop in Nashville, TN JohnTN Tennessee Jeep Forum 8 06-19-2016 06:21 AM
Need a good mechanic, a JEEP mechanic bamaboy YJ Wrangler Technical Forum 6 02-14-2011 09:20 AM
Good Jeep Mechanic in Central NJ?? Jeanny's YJ YJ Wrangler Technical Forum 19 11-06-2007 10:06 PM
good Jeep mechanic in San Antonio area? red92YJ YJ Wrangler Technical Forum 6 04-11-2007 10:54 AM
Looking for honest, good jeep mechanic Stormtrooper TJ Wrangler Technical Forum 7 01-28-2004 10:05 AM
