Jeep problem: Check engine comes on, idle raises, smells like gas - JeepForum.com
post #1 of 5 Old 07-18-2008, 03:43 PM Thread Starter
Hotimportcrx
1994 Jeep Wrangler
4 cylinder 116k
Any ideas what this could be?
Hotimportcrx is offline
post #2 of 5 Old 07-18-2008, 04:40 PM
NJeepyj91
What code are you getting?
usually these issues are related to vacuum leaks, intake or exhaust leaks and even a bad O2.
Other causes, more rare, but can happen. Fuel injection issue or a sensor issue. Need more info.
Pull the code.
She's going to bury me in this thing.
91 4.0 stick. Posi Lok, Borla, 31s on steelies, Dem Bonz Shackles and lots of other junk on my junk.
NJeepyj91 is offline
post #3 of 5 Old 07-18-2008, 05:30 PM
MissMurder
Enemy of all chicks
MissMurder's Avatar
Take it to an auto parts place, autozone etc. Have them run the code. Could your be TPS also. Ask me how I know
Black Jeep Club V2.0 Member #218
Just so you all know, If I think you're an ******* I will gladly tell you. I'm not your everyday girl, so don't expect me to act like one. And yeah, I do like it topless and dirty!
Quoted Jetscuh: "I really have to force myself to eat nuts. There are other forms of protein as well, but it can be hard making sure you get enough at times."
MissMurder is offline
post #4 of 5 Old 07-18-2008, 05:44 PM
IRIDEKTM
You can turn the key on off on off on and you will get blinking engine light codes. it will blink a certain amount of times close together for the first number, and then a pause, then blink again for the second number. Should come out with like 24 or 45 or 34 for example. Post those numbers up if you dont have a haines manual and ill check them out for you or if you do have a haines it has all the engine blinking codes in there.
Mine does that in my 4.0L and reading mostly o2 sensors and rich or lean mixture
good luck
LIVE IT BEFORE YOU KICK IT
IRIDEKTM is offline
post #5 of 5 Old 07-18-2008, 05:52 PM
NJeepyj91
ssssh Angel. I'm dazzling them with my stupidity.
Really, I just want to get peeps into the mind set of the basics so they can save some cake.
YJs are Zen relaxation for me.
Back to Tech. I suspect your getting a 02 sensor code. Rich.
Outwornangel is giving some very good advice with the Autozone suggestion.
check engine light and rough idle kllrbee TJ Wrangler Technical Forum 11 06-04-2009 12:40 PM
2004 TJ help... (check engine light, erratic idle) spYder miKe TJ Wrangler Technical Forum 11 04-28-2008 05:16 PM
2.5l Rough Idle & Check Engine Light Copywriter TJ Wrangler Technical Forum 3 01-08-2008 09:35 PM
idle dip, check engine light Poor Boy TJ Wrangler Technical Forum 4 10-11-2006 01:48 AM
Check engine - high idle nmarsh TJ Wrangler Technical Forum 5 04-05-2005 11:40 PM
