Jeep only shifts when off - JeepForum.com
post #1 of 5 Old 01-16-2015, 07:00 PM Thread Starter
YJ4LIFE
After driving for 20 min or so it gets harder and harder to go into gear. If I'm parked somewhere and have to do a 3 point turn I have to turn off the jeep when I stop to be able to get into first or reverse. What the hell is going on???
'89 YJ, 4.2L, ax-15, B&M shifter, 1" BL, TJ flares, '99 intake, '91 EFI, 5.0L explorer injectors, GenRight tank & stretch, 35" ProComp Xtreme muds, 52" chevy springs rear, 44044 Ranchos front.....
YJ4LIFE is offline
post #2 of 5 Old 01-16-2015, 07:24 PM
plym49
Clutch is not releasing all the way. When the tranny is cold there is more drag to slow down the countershaft. When it gets warm that doesn't happen, so it is harder to shift.
Maybe your clutch master is low on fluid. That's the easy fix and if it is not that you will have to do a deeper dive.
plym49 is offline
post #3 of 5 Old 01-16-2015, 08:41 PM
Opihi59
from here it gets rough
Opihi59's Avatar
I do concur with plym, I believe what you are describing is caused by a failing hydraulic system. Look for leaks from your clutch master or slave either inside the firewall under the dash where the rod comes thru from the clutch master, or dripping from the bellhousing from the internal clutch slave. And of course, check the fluid level in your clutch master cyl reservoir. I'm going to guess it will be low.
If you are able to range thru your gears fine with the engine off, and it doesn't want to shift at all when running, your problem isn't inside your tranny but likely hydraulic related.
....I'm not smart, but I can lift heavy things.......
Fill out your PROFILE, and don't forget to look in the FAQ for writeups
I'm stuck on da Rock
Originally Posted by Brian4.2 View Post
We will be going Metric every inch of the way.
Originally Posted by 40dog View Post
yes I'm a some guy and have always put gasket sealer on my surfaces before mating
Originally Posted by Virjeep View Post
You should go to Pirate. I hear they are real smart over there. You'd fit right in.
Opihi59 is offline
post #4 of 5 Old 01-16-2015, 10:16 PM
UltimatE
Resident Audio Guru
UltimatE's Avatar
x3 on clutch not releasing properly.
-Matt
White '94 YJ Sport
Green '94 XJ Sport - 57,000 Original miles
UltimatE is offline
post #5 of 5 Old 01-23-2015, 12:59 AM
TennesseeYJ
Yep ... what they said.^^^^ I experienced the same thing. New clutch master & slave cylinder and I was good to go!! Make sure you bleed it well or it will still act up. Air in the system compresses .. brake fluid doesn't. Good luck !
1991 Jeep Wrangler YJ, <-- My Jeep is a pickpocket!!
1984 Mustang GT Top 5-Speed <-- Running soon hopefully
2003 Honda Shadow Spirit 750, 1994 Suzuki Katana 600, 1980 Yamaha XS650 <-- Ripped apart and under the knife .. Chopped, bobbed & mono shocked. I got too many toy$$$!!!
TennesseeYJ is offline
