Jeep not starting after clutch and transfer case replacement - JeepForum.com
post #1 of 26 Old 10-17-2013, 06:42 PM Thread Starter
_Chippy_
I was hoping you guys could help me out. I've got a 1994 YJ. Not too long ago, the rear wheel draft shaft came apart at the U joint while I was driving. Needless to say, the transfer case didn't survive the incident. The tranny was having issues anyway, so I had a friend of mine replace both the tranny and transfer case. Anyway, after all said and done, the Jeep will not start. It doesn't even try to turn over. You turn the key and dash goes out and comes back on when you release it. No clicking, or any noise really, from under the hood. Any help would be GREATLY appreciated.
Disclaimer: First off, the friend in question is no longer available. He travels for work and is currently out of the state, on night shift. We've been playing phone tag with no luck. Secondly, I'm an industrial mechanic by trade. I know a little about auto mechanics, and understand some of the lingo, but I am in no way, shape, or form an auto mechanic. I have no issues doing the actual work, but if I ask a stupid question, please bear with me.
_Chippy_ is offline
post #2 of 26 Old 10-17-2013, 06:47 PM
Apollo12227
What transmission? Fill out your profile please.
Silly question but did you hook up the starter wires when you put the tranny back in and the starter back on?
Apollo12227 is offline
post #3 of 26 Old 10-17-2013, 06:52 PM
SamzJeep
SamzJeep's Avatar
Neutral safety switch?
SUPPORT OUR TROOPS
SamzJeep is offline
post #4 of 26 Old 10-17-2013, 06:55 PM Thread Starter
_Chippy_
AX5 tranny I'm pretty sure. I thought about the Neutral Safety Switch, but looking online, I'm inclined to believe it doesn't have one. I've never tried to start it without pressing the clutch in before all of this to be honest.
_Chippy_ is offline
post #5 of 26 Old 10-17-2013, 07:33 PM
flcracker
No neutral safety switch....
Does everything but the starter come on?? (lights, cel, fuel pump prime)
Not the sharpest bulb in the box....
My Jeep is possessed with the goal of making me lose my religion....
flcracker is offline
post #6 of 26 Old 10-18-2013, 06:19 AM
JohnRodriguez
make sure the engine ground stap is hooked up. its easy to forget about it
89 Wrangler, 2.5L TBI, D30 Truetrac 4.56 gear front, Super 35 4.56 gears rear, 31" BFG Mud's, 15x9" weld racing pro-stars XP's, 2.5" rancho and 1.25" shackels, superior axles. rear wilwood disc brakes
2008 wrangler x unlimited. Stone white. Motech 5.3L LS Chevy
JohnRodriguez is offline
post #7 of 26 Old 10-18-2013, 07:20 AM
Siva283
If the lights go out when you hit the key and come back on when you let off. I would beleive eithier your battery is dead or the start is bound up. So make sure your battery is charged first.
Ask me how I know...
Siva283 is offline
post #8 of 26 Old 10-18-2013, 09:07 AM
laybackman
Bikini Bridge Inspector
laybackman's Avatar
2010 JK Wrangler
Make sure the battery is fully charged. As previously mentioned check the grounds especially the engine ground strap. Check BOTH battery cables to make sure they are clean and tight. Give the starter a couple of hard taps with a hammer, since it may be bound up.
Do you know what was good about the good old days? I wasn't good, And I wasn't old!
Senators and Congressman should wear uniforms like NASCAR drivers so we could identify their corporate sponsors....
laybackman is offline
post #9 of 26 Old 10-18-2013, 09:36 AM
Que89YJ
You dont have a Nuestral Saftey switch but you have the wiring. I bet your reverse lights are not working either. There is wiring and a connector going down the pass side of the engine compartment near the middle. (I think its a 6 pin connector, not 6 wires but 6 pin)You either didnt connect it or the wiring at the tcase/trans.
Que89YJ is online now
post #10 of 26 Old 10-18-2013, 12:55 PM Thread Starter
_Chippy_
Reverse lights come on. I'm getting ready to crawl under it and play with the starter. I'll give you guys and update when I know more. And thanks for all of the replies!
_Chippy_ is offline
post #11 of 26 Old 10-18-2013, 01:06 PM Thread Starter
_Chippy_
Quick question. I didn't take part in the starter being removed when we did the tranny. Is there a way to make sure it was wired back correctly. I know, under normal circumstances, you label the wires before removing it. What if the wires were attached to the wrong posts?
_Chippy_ is offline
post #12 of 26 Old 10-18-2013, 01:21 PM
Que89YJ
Jumper the starter relay in the PDC from pin 30 to 87. It put power to the brown wire on the starter and should crank it over unless the NSS is messed up. You should also try using the jumper cables and put power from the battery strait to the starter.
post #13 of 26 Old 10-18-2013, 01:25 PM Thread Starter
_Chippy_
Alright, put that in slightly stupid terms for me.
_Chippy_ is offline
post #14 of 26 Old 10-18-2013, 01:26 PM Thread Starter
_Chippy_
Also, I tried jumping the battery, no avail. I do get what sounds like an electrical motor going when I crank the key. I assume its the fuel pump?
_Chippy_ is offline
post #15 of 26 Old 10-18-2013, 01:49 PM
Que89YJ
Take a 3" piece of wire and pull the starter relay in the pdc. Look at the side of the relay it has a pic of the numbers on the side of the relay. In the relay socket the relay plugs into, connect the wire from 30 to 87 and see if the starter turns over. If it doesnt use a jumper cable and connect from battery positive to the hot terminal on the starter and see if it starts.
