Jeep Newbie - JeepForum.com
post #1 of 19 Old 10-01-2013, 04:44 PM Thread Starter
JeremiahYJ
Jeep Newbie
Hello fellow jeep owners, I just recently got my Jeep Wrangler 88 last Saturday and was wondering if you guys can help me out a bit? with mods and how things work.
JeremiahYJ is offline
post #2 of 19 Old 10-01-2013, 05:06 PM
jbolty
jbolty's Avatar
Welcome.
Specific questions will yield better results.
jbolty is offline
post #3 of 19 Old 10-02-2013, 01:46 PM Thread Starter
JeremiahYJ
Which mod would have less down the road problems; suspension or body lift?
post #4 of 19 Old 10-02-2013, 01:49 PM Thread Starter
JeremiahYJ
Also how would I go about dealing with rust? I live near Chicago so the winters get pretty intense is there any spray I can use to stop the form of rust?
post #5 of 19 Old 10-02-2013, 04:44 PM
Apollo12227
You don't really want to go above 1" with a body lift. Larger body lifts put a ton of strain on the body mount locations. There have been instances where cabs have detached from the frame due to the long body lifts.
Suspension lift is of course more money. Leaf springs are a pretty simple technology so they arn't very pricy. You would first need to decide if you want to go spring over or remain spring under. As each option will yield much different needs with regards to what suspension leaf springs to get... Among other things.
Clean the underside of your jeep often. Especially in winter. Salted roads will absolutly DESTORY a YJ. I have heard of some people completely cleaning and then painting the underside of their jeeps and frame with udnercoating or POR15. This is a good way to go.
For a temporary solution, clean underneath it and spray it in WD40 or coat it lightly in motor oil... Sure will make a mess of things, but it will protect... Again, the "right way" is to chase out all of the existing rust, and apply some sort of heavy undercoating.
Apollo12227 is offline
post #6 of 19 Old 10-02-2013, 04:55 PM
YJ4LIFE
start with things you dont have to redo later. like 1" body lift and TJ flares.
'89 YJ, 4.2L, ax-15, B&M shifter, 1" BL, TJ flares, '99 intake, '91 EFI, 5.0L explorer injectors, GenRight tank & stretch, 35" ProComp Xtreme muds, 52" chevy springs rear, 44044 Ranchos front.....
YJ4LIFE is offline
post #7 of 19 Old 10-02-2013, 07:43 PM
dancytron
Mine was from Idaho and rust free when I bought it 4 or so years ago.
Every fall and every spring I clean the underneath really well at the car wash (the first time I did it I used orange grease cutter and then wiped everything down with acetone). Then spray everything that is rusty with Rustoleum Rust reformer. Probably not as good as Por 15 or the stuff from eastwood, but if you keep it at, it seems to be doing the job.
I take to to the car wash and wash the rust off every chance I get during the winter.
I also did the Eastwood inside the frame treatment (one can on each side).
dancytron is offline
post #8 of 19 Old 10-07-2013, 10:11 PM Thread Starter
JeremiahYJ
Thank you guys for the info! As you can tell I'm fairly new to Jeeps and the community. I will post some pictures of my jeep sometime this week. Back to the lifts, will a 1inch body lift clear 31"? Also, if you guys can post pictures of your jeeps?
post #9 of 19 Old 10-08-2013, 01:06 AM
Sparrows
Welcome to the cool kids table!
A 1" BL will help clear 31s. I'd say you need at least 1.5" to really "clear." So look into a 1/2" shackle lift. The YJ I just picked up has 31s on stock springs and I have destroyed the flares the last couple trips out.
And since you wanted pics....
My last '93
My current '95 (Look at that back tire just eating up that flare!)
Aaaaand my brother's new '94
Again, welcome to the forums. Figure out how to use the search function. It will save you a TON of headaches! Read, read, read, and read some more on here. There in more information on JF then you can imagine.
Cheers
June '13 YJOTM
Sparrows is offline
post #10 of 19 Old 10-08-2013, 11:11 AM
Mobile_Homie
Desert Rat
Mobile_Homie's Avatar
My last '93
Cheers
The pics....Lucky Peak??
Mark
Smoke em if you got em!
Mobile_Homie is offline
post #11 of 19 Old 10-08-2013, 01:05 PM
Spike6901
If I were you (and will be in a few months), I would start off by going through the entire Jeep and performing a full tune up and maintenance first before throwing mods at it. That way, you know what you have, how to work on the Jeep a little and bypass some of those annoying issues that can crop up.
-Change the oil, diff grease, xfer case, tranny, engine oil and coolant (flush). Inspect fluids for anything out of the ordinary.
-Check your coolant hoses, thermostat and radiator. Replace as needed and pick up some spare hose and clamps.
-Change the fuel filter and check all of your fuel lines for rust and/or cracks.
-Pull a spark plug or better yet, change them 'cause they are cheap.
-Inspect the cap, rotor and plug wires, or better yet, just replace them 'cause they are cheap too.
-Check your vacuum hoses and wiring for anything cracked, broken or rigged. Fix splices and secure anything that is hanging loose. Nothing sucks worse than electrical and vacuum gremlins that ruin your day.
-Check your u-joints in the drive shafts and verify they are in good shape (I would replace them anyway before installing a lift with greasable type)
At this point, you would have spent some money but have gotten dirty and know the ins and outs of your Jeep. You never know what the previous owners have messed with or not done like they should.
I performed this on my old Land Cruiser and you would NOT believe the crap that I found that was hidden from view. I ended up having to re-wire most of the back half of the truck because of how many splices and rigs there were. I also found a u-joint that self distructed in my hands, an oil seal that would have gone any day, and enough other things that made be feel real good about taking that time.
Now you are ready to throw mods at it.
Future: '17 WK2
Current: '97 ZJ - Lots of mods
Past: CJ-7, XJ, KJ, JKU
Spike6901 is online now
post #12 of 19 Old 10-08-2013, 01:16 PM
seatown7
Here is a pic of my 2001 TJ with a 1 inch body lift and 31s. Welcome from another noob.
seatown7 is offline
post #13 of 19 Old 10-08-2013, 01:31 PM
Hoxie
1987 YJ Wrangler
Welcome!
As Sparrows said I'd look into some boom shackles and go from there. You can find them for around $80 on up. Dont go over board with them just 5/8 to 1/2 should do it. Theres a guy on the forum that makes them, somebody around here can help ya out.
Heres my 87.
Hoxie is offline
post #14 of 19 Old 10-08-2013, 01:32 PM Thread Starter
JeremiahYJ
Should of probably said this earlier but my jeep will be a daily driver as this is my first car (I know a jeep isn't a car) I just want to add a little 'muscle' to my jeep my next jeep though, I will want to do some off roading. but thank you Spike6901 as well as the rest of you. I definitely will read, read, and read even more through the forums, half of the time I don't even know what to look for but I will get there. I will have pictures of my baby up later on today!
post #15 of 19 Old 10-08-2013, 01:35 PM
Hoxie
1987 YJ Wrangler
Thats how we all started... lol welcome to the F12.
Hoxie is offline
