jeep keeps popping radios - JeepForum.com
post #1 of 11 Old 08-22-2011, 08:11 PM Thread Starter
YJSheep1
1987 YJ Wrangler
So my 87 wrangler has had 3 radios go through it. Its getting very expensive and aggravating, So here's what happens. I get a radio use it for awhile and one day it just stops working. I have a full blown sound system with subs and a kenwood 450 amp. Just trying to see what everyone thinks. Thanks
YJSheep1 is offline
post #2 of 11 Old 08-22-2011, 08:27 PM
sbsg2005
do you have a bare wire under the dash that could rub the case? this happened to a couple radios in a camaro i had took me 4 or 5 to figure it out.
sbsg2005 is offline
post #3 of 11 Old 08-22-2011, 09:31 PM Thread Starter
YJSheep1
1987 YJ Wrangler
No, it's all fresh wires. I did just find the remote to the amp wasn't hooked up. i'm thinkin thats it, but i already complained to pioneer and what they don't know won't cost me...
YJSheep1 is offline
post #4 of 11 Old 08-23-2011, 01:04 AM
Tom95YJ
[] Eye'd Jeep Connoisseur
Tom95YJ's Avatar
Did you wire it yourself or did a shop wire it up for you? If you've gone threw that many stereo's you have a wiring issue or bad ground somewhere. Seeing that your system remote isnt hooked up I'm going to assume you installed it yourself. What I would like to know is how in the hell is a 450watt amp powering Subs and 20 speakers ? Your sound quality must be **** ! . Do yourself a favor next time you get a new head unit goto a good car audio shop not Best Buy an actual car audio shop! Have them go threw your "system" and install the headunit for you. Be prepaired to pay a few hundred dollars and be laughed at but they will know what they are doing and install it properly making sure you wont have a Car-B-Que
I never had any issues with any of the systems I've installed quite a few and never had 1 single issue. All I use are Pioneer head units . I would always use the constant power, switched power and ground from the factory harness and I wouldn't use the other wires . I would use system remote and RCA's to the amps then the amp power kits to a capacitor then the amps I used an mono amp for the sub, and a 4ch for front/rear speakers. I would always run the Positive and negative/ground cables on opposite sides of the vehicle.
'89 YJ The Smurf
'99 XJ Black Betty
Last edited by Tom95YJ; 08-23-2011 at 01:23 AM. Reason: 450watt amp powering a 20 speaker system :eek:
Tom95YJ is offline
post #5 of 11 Old 08-23-2011, 05:13 AM
grandboost98
^what he said, also run your positive and RCA cables opposite each other
04 Grand Cherokee Overland
72 Chevy Nova-in progress
grandboost98 is online now
post #6 of 11 Old 08-23-2011, 07:29 AM
Que89YJ
The easiest way I can think of to destroy a good stereo or any electronic in the car is load dumping it. Basically taking a car thats running and disconnecting and connecting the battery while a bunch of different things are running like lights, blower, radio etc.
The alternator is putting out a lot of current and the battery disconnects the current is going to go somewhere. Make sure you have the battery terminals connected solid and the ground cable is tightly connected to the chasis.
Que89YJ is offline
post #7 of 11 Old 08-23-2011, 07:38 AM
EABiker
And... since it is a Jeep, that means that water will drip on the radio every time it rains, plus, small pieces of rust will drop into it every time it hits a bump since it leaked every time it rained!
A plastic shield over the radio does wonders for those problems.
EABiker is offline
post #8 of 11 Old 08-23-2011, 10:50 AM
5.7YJ
5.7YJ's Avatar
1987 YJ Wrangler
^^^^^Maybe a bad cowl seal letting water pour right into the radio? A plastic shield is a good idea EABiker!
87 YJ, TPI 5.7, 700R4, NP231, BDS 3.5" lift, 1" front & 5/8" rear boomerang shackles, Rubicon Dana 44 rear axle, 33" Goodyear Duratracs
My brake boster/master cylinder upgrade:
5.7YJ is offline
post #9 of 11 Old 08-23-2011, 10:52 AM
hesserdude07
both posts are a WIN.
1993 Silver YJ. SBC 300hp. 700r4. NP231 hybrid. 35" Mud Terrains. 7" Toyota Basterd packs. 8.8 Welded. D30 loc-rite. 1" body lift. 4" LED tails. Custom bumpers. Warn M8000. Hella's. (Trail rig)
hesserdude07 is offline
post #10 of 11 Old 08-23-2011, 10:09 PM Thread Starter
YJSheep1
1987 YJ Wrangler
I chased all the wires, no bare spots, good grounds, the remote wasn't hooked up because the subs were out and the tape fell off...oops... and the amp only powers the 2 subs. I tested the volts at the head and when the rpms hit the shift points the volts spike to 16 so I'm gonna say its a bad voltage regulator. who knows where it is on an 87?
YJSheep1 is offline
post #11 of 11 Old 08-24-2011, 06:07 AM
Que89YJ
16 volts is a little high you should see 14.5 Vdc when running. I would double check the meter though before I did the next step. The voltage regulator for the pre OBDI(pre1991) is internally regulated(Inside the alternator). If you feel that the voltage readings are correct there is a very very cheap popular mod to upgrade the alternator to a GM CS-144. It has about 40% more capacity and you can get one from the scrap yard for $30 or $40 dollars.
http://www.jeepforum.com/forum/f12/delco-cs144-1187379/
http://www.jeepforum.com/forum/f12/d...rnator-839918/
http://www.jeepforum.com/forum/f12/a...stion-1017658/
Que89YJ is offline
My Jeep keeps popping out of 4 high JeepDelaware TJ Wrangler Technical Forum 15 01-18-2014 11:47 PM
popping from rear end of jeep 06WranglerX TJ Wrangler Technical Forum 3 06-20-2011 09:00 PM
POPping from the bottom of jeep buckjflowers TJ Wrangler Technical Forum 10 01-31-2010 09:21 PM
jeep popping out of 5th platinumjeep TJ Wrangler Technical Forum 0 03-19-2009 08:44 PM
Popping noise from Rear of Jeep Mr Ouija TJ Wrangler Technical Forum 16 11-24-2002 08:49 PM
