Jeep Idleing rough and trouble codes 23 27 - JeepForum.com
post #1 of 6 Old 08-23-2011, 01:34 PM Thread Starter
smoan
I went to the gas station the other night and my jeep ran fine. i got gas and checked my fluids and started it back up. The engine idled rough and had a kinda shake and the check engine light came on. it had codes 23 and 27 which are Logic module fuel circuit internal problem or TBI injector does not respond properly to control signal and Intake air temperature signal out of range what could that mean is wrong?
smoan is offline
post #2 of 6 Old 08-23-2011, 06:55 PM
oldtime_ironman
My Haynes manual says Manifold Air Temp sensor and Fuel Injection Control. I'm guessing that the MAT sensor is the problem, which in turn is feeding bad signals to the ECU. The ECU gets the bad signals and then sends bad signals based in the MAT, to the injector controls. Therefore take a look at the MAT sensor. Not sure how to test that one myself, tho.
oldtime_ironman is offline
post #3 of 6 Old 08-23-2011, 07:46 PM Thread Starter
smoan
i was working on it today and i took out the injectors and let them sit in injector cleaner and blew them out with air compress. i put them back on and the check engine light isn't on when its running. and it doesn't idle rough anymore but it does idle at 2000 rpms it has the 4.0 throttle body on it if that affects anything
smoan is offline
post #4 of 6 Old 08-23-2011, 07:58 PM
oldtime_ironman
Nah the 4.0 throttle body shouldn't affect it. Did you try cleaning the throttle body out real good? Especially the IAC valve cuz of the way its idling too high.
I'm assuming the o-rings on the injectors are OK and didn't get scratched up.
Forgot to add, make sure you cleared out the old computer codes.
post #5 of 6 Old 08-23-2011, 08:17 PM Thread Starter
smoan
i just reset the computer and it fixed my idling issue but i did take apart the throttle body and cleaned it out trying to solve my problem. My o rings looked in good shape but if i did mess them up would there just be a fuel leak or any other symptoms i should look out for just to make sure. Thanks for your help.
smoan is offline
post #6 of 6 Old 08-23-2011, 08:28 PM
oldtime_ironman
OK so the idle is back to normal after re-setting the computer? No more 2000 RPM's and its smooth? GOOD!
Nah you wouldn't necessarily see a leak at the injector tip where it goes into the manifold. You could always test that by spraying around them with some carb cleaner - the idle will go up if there's a leak pulling vacuum.
If an o-ring leaks where they plug into the fuel rail, then yeah you might get a drip because its under pressure.
But honestly, I think you got it taken care of, and no more worries.
jeep wrangler idleing too high terry1 YJ Wrangler Technical Forum 12 12-09-2009 11:31 AM
FAQ - Check Engine Light and Diagnostic Trouble Codes (Error Codes, Problem Codes) Wheelin98TJ TJ Wrangler Technical Forum 6 05-15-2009 05:05 PM
idel or idleing rough yjjustforme YJ Wrangler Technical Forum 3 02-11-2009 07:31 PM
rough idleing JDON YJ Wrangler Technical Forum 1 01-27-2009 01:12 PM
Jeep running rough after A/C on for a while. Anybody know error codes??? Dom45ACP TJ Wrangler Technical Forum 1 07-11-2007 08:12 AM
