Jeep Header swap issues - Page 2 - JeepForum.com
post #16 of 30 Old 03-06-2013, 06:07 PM
Que89YJ
Still having high rpm?
Fault codes:
Mean Max pics of everything:
No Start:
Que89YJ is offline
post #17 of 30 Old 03-06-2013, 06:22 PM Thread Starter
dpr333
Yea, crazy high. It starts around 1800 and steadily rises without me touching anything. It will keep going until I get worried and kill the motor
dpr333 is offline
post #18 of 30 Old 03-06-2013, 06:35 PM
Que89YJ
It sounds like the iac.
Fault codes:
No Start:
Que89YJ is offline
post #19 of 30 Old 03-06-2013, 07:25 PM
95yj0645
I would almost lay $5 down that you have something pinched under the intake manifold, or the alignment dowels are stuck causing a rather large vacuum leak. I had the EXACT same issue when I did my header. Ended up I was torquing down on a crooked dowel and it was sucking air past the throttle body causing my idle to sky rocket. I mean you didnt do anything except put a header and bigger injectors correct? the injectors I would imagine would make it run rougher until you match the extra fuel with more air. my $0.02.......
95yj0645 is offline
post #20 of 30 Old 03-11-2013, 11:05 AM
Que89YJ
Any updates?
Que89YJ is offline
post #21 of 30 Old 03-11-2013, 01:15 PM Thread Starter
dpr333
Nothing yet. Had a rough weekend.
I am going to completely take the intake manifold off tomorrow and start fresh. It's gotta be a vacuum leak do to the fact that I didn't touch anything beside swap the headers and Injectors. I put the old injectors back in with no fix
95yj- are you referring to the alignment dowels coming out of the block,?
dpr333 is offline
post #22 of 30 Old 03-12-2013, 10:06 PM
Fuzzy_Wuzzy
Yeah I see it's posted but my bet is that it is not sitting against the head right and pulling extra air in.
Fuzzy_Wuzzy is offline
post #23 of 30 Old 03-12-2013, 11:07 PM
rambo3489
Wouldn't a leak on the intake manifold cause a lean mixture causing the engine to die. Not rev higher? This happened to me on my 4.0 head swap. The intake manifold was hitting the headers in two places not allowing a proper seat. Thus sucking in air like crazy. It would not idle unless I kept feeding it the gas.
89 YJ.. My first jeep and I won't let it go. ▀||||▀
Current Project: None... I disgust myself.
<a href="
THE YJ MY WAY</a>
rambo3489 is offline
post #24 of 30 Old 03-13-2013, 07:59 AM
Que89YJ
No it's a vacuum leak so the ECU thanks its idling too low and runs a higher rpm.
Fault codes:
No Start:
Que89YJ is offline
post #25 of 30 Old 03-13-2013, 12:36 PM
Siva283
If its the intake that is leaking the ECM would see a lean condition and add more fuel since it cant control the air getting in there. Correct me if I am wrong someone. That would mess vacuum up also and cause it to be low as far as the ECM is concerned. Break out the carb cleaner and spray it around the mating surfaces and see what happens.
Ask me how I know...
Siva283 is offline
post #26 of 30 Old 03-13-2013, 05:57 PM
Que89YJ
Yes. but the map sensor is the big issue. It sets advance and would think the idle is low. The O2 is looking at the air fuel mix.
Fault codes:
No Start:
Que89YJ is offline
post #27 of 30 Old 03-13-2013, 06:25 PM
Siva283
He said he hooked map back up with no change.
Sent from my Galaxy S3 using JeepForum
Siva283 is offline
post #28 of 30 Old 03-13-2013, 06:46 PM
Que89YJ
Yes. I think it's a vacuum leak throwing off the map. Make sure to disconnect the battery to clear the ecu.
Fault codes:
No Start:
Que89YJ is offline
post #29 of 30 Old 03-13-2013, 06:48 PM
Siva283
Gotcha I miss understood what you were saying.
Siva283 is offline
post #30 of 30 Old 07-12-2013, 11:42 AM
dhyasyn
I had the same problem when I swap my header out. just torque the intake manifold down tighter, its just a leak sucking in air.
dhyasyn is offline
