Jeep has trouble starting. - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > YJ Wrangler Technical Forum > Jeep has trouble starting.
Only 2 Days left to win $3,800 Jeep Parts!Count Down to KOH Sale!Introducing MONSTALINER™ UV Permanent DIY Roll On Bed Line
Unread 11-29-2011, 09:16 PM   #1
ErikPeterson
Recently my Jeep has been slow to start in the mornings but never fails. Twice midday I have turned the key, and the fuel pump makes its noise it does when it turns on, and the starter just clicks once. Then all the lights die out. After 15 min on both occasions, it decides it wants to start, very easily. I replaced the starter a couple months ago, and it has started fine till recently. I know its not the battery. Please help. Thanks.
1990 Wrangler YJ "Linda"-Project
2012 Patriot Sport FD1 "Beth"-DD
ErikPeterson is offline   Reply With Quote Quick reply to this message
Unread 11-29-2011, 09:37 PM   #2
ROWA
ROWA's Avatar
Check the ignition switch, or turn the key to the on position and place a screw driver between the battery connector and the solenoid. If it fires up right away it is most likely the ignition switch. The ignition switch is inexpensive it is just a pain to install.
94 YJ Sahara
The best Engineering is no match against natural Stupidity.
ROWA is offline   Reply With Quote Quick reply to this message
Unread 11-29-2011, 09:49 PM   #3
ErikPeterson
Thank you
Unread 11-30-2011, 05:25 AM   #4
ErikPeterson
Also it has been raining since Sunday here, could water getting into the starter be it?
