Jeep has been sitting, now having gauge problems
| GR8TOPS Introduces the Exogate HD Tire Carrier | The Original 3/8" Ruffstuff Diff Cover! | Ruffstuff Axle Simple Swap Kit! |
#1 | |
BUILT. NOT BOUGHT.
After the jeep sat for a little over a month while i got my wheelbase stretch, axle swap, and fuel cell install done... I cranked her up for the first time and have gauge problems!
first off, coolant temp. it stays cold, all the time. does anyone know what resistance the sending unit should output while the engine is cold? how about at proper operating temp? if i take the wire off the sending unit and ground it out, what temp shoudl my gauge show? how about it i just simply unplug it? next is my fuel gauge. it worked fine with the stock tanka nd sending unit. now i realize that the resistance for my gauge and sending unit aren't going to match up right... but... when i take the wire that went to the oem sending unit and ground it out, what should the gauge read? how about when i leave the wire danging and not connected to anything? seems to me like the gauge should show two opposite readings... one full, one empty. the gauge doesn't. it just stays at full all the time. not too worried about this but if you have an idea, speak up. thanks clock stopped working. this sucks, but i should have expected it a long time ago. can i buy a replacement clock ONLY? or do i have to buy the whole cluster? I was told i could buy just the clock but i want to verify this since my local dealership said i could not..... thanks guys -Erik <--- forgot how mean the 2.5 sounded with it's new flowmasterrrr!
'89 Wrangler, 4.0/AW4, 106" Wheelbase, SOA, custom XJ packs, 2" Body. Front High Pinion Dana 44 w/yukon super-joints, chromo inners and outers, and a Lincoln Locker. Rear Dana 60 w/Yukon 1.5" 35 Spline chomo shafts and detroit locker. 5.38 Yukon Gears. Hydro-Assist, 39.5x18" Boggers on 15x12 RockKrawler's w/ 2.75" of backspacing. Comp cut, tube fenders, custom bumpers and rock sliders, fuel cell, CB, Stewart Warner Gauges, SmittyBilt XRC8 Winch, 140 Amp CS-144 Alternator, Electric Fan, and a cooler of beer. 3897 lbs March 1st, 8pm. WILMINGTON, NC MEET & GREET @ HOOTERS! |
#2 |
I know for sure the YJ fuel guage is 0 ohms empty and 90 ohms full. I just replaced all of mine with Autometer guages. I'm not sure about the temp sensor. Have you checked to see if the sending unit is still connected the wire going through the firewall?
Baltimore 4 Wheelers. www.baltimore4wheelers.org "Haven't you outgrown that yet...." - my wife. |
#3 |
BUILT. NOT BOUGHT.
coolant temp sending unit wire is still connected. my multimeter is in my neighbor's jeep which is MIA as his ******* drove it to the bar last night and can't remember where he parked it.....
the rci fuel cell's sending unit is 0 ohms empty, 90 ohms full ohms just like you said your stock sending unit was.... i was under the impression the stock sending unit was opposite what you just told me but after reading all this stuff about sending units it's very possible AND LIKELY that i'm just confused. If what you tell me is right I'll be very happy. my 89 yj should ahve the same tank and sending unit as your 89 4.2, shouldn't it?
#4 |
I would hope the fuel sending unit for the 2.5 is the same as the 4.2, but I am not 100% certain. Do you have a FSM? If not I could look it up in mine and see what I find.
#5 |
BUILT. NOT BOUGHT.
ok
this is what i've found ![]() appears that sending unit assemblies are different... but work the same... only difference appears to be that mine has a in-tank pump while yours does not. here is the testing procedure... i'll be doign this tomorrow after work. ![]()
Fuel Gauge (Dash Unit) - oem part # 56001386 price $43.00
#6 |
BUILT. NOT BOUGHT.
as for coolant stuff, here goes what i've found
#7 |
Hey Big n Broke. Nice schematics!
89' YJ Larado 4.0L,AX15 01' Grand Cherokee 4.0L Check my Gallery for pics. My Rebuild Thread Take a minute and fill out your profile, Please |
#8 |
BUILT. NOT BOUGHT.
this is all i could find really...
#9 |
BUILT. NOT BOUGHT.
i can't find squat more on alldata....
#10 |
That's OK. You got that info from Alldata? I was gonna subscribe to that but didn't know what kind of info I could actually get from it. Looks like some good stuff. Anyway that pic helps me. Looks like voltmeter is just pulled from Fused gauge power on terminal #2. Cool
#11 |
BUILT. NOT BOUGHT.
check your pm
#12 |
Burnerman, you are correct in your assumption. The voltmeter does simply measure the voltage in the line from the fuse panel, nothing special there. I was tired of tracing through the mess behind the guages and splicing wires over the broken copper sections. I replaced every gauge and made my own harness. No more problems.
Big-n-broke-yj, Those pages are straight from the FSM, so you are getting good information. Your guages may be shot at least some of them.
#13 |
BUILT. NOT BOUGHT.
yes it sounds like i may have problems with the gauges themselves... which leads me to jump into this gray area... replacing oem gauges with autometer.... you mention you did this... any pics or details? i know on eBay a guy sells a bracket, and i know autometer or someone makes a piece that replaces that whole thing and holds the gauges at an angle.... just never seen it in person and curious how it all fits and works out in the end.....
#14 |
BUILT. NOT BOUGHT.
ribbon on the back side of the gauge assembly has corrosion all over it. found my problem.
i'm not gonna fix it. the gauges look like crap anyway and they all start acting up if i tap them. autometer, here i come... one at a time maybe... but here i come....
#15 |
Once I finally decided to purchase new gauges I thought for a while about the dash. I ended up buying a new gauge pod from Quadratec. This new pod looks exactly like the stock one except the gauges are angled progressively towards the driver as they move from left to right. I shopped the gauges separately and bought most of them off eBay. I purchased the Autometer Phantom II ones with the white face and red needle.
They all fit nicely into the new pod and I set to wiring them up. I created a new harness for the gauges so I could disconnect them easily should I ever need to pull the dash. I tapped into the stock harness wires and soldered/heat shrinked the wires for the new harness into their respective locations. I can pull the entire pod out and disconnect the connectors very easily. I am sorry I did not take any pictures during the process. I can take some shots of the finished dash. I'll try to get them in the next day or so.
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
