jeep drives in reverse but doesnt drive in drive - JeepForum.com
post #1 of 3 Old 12-20-2010, 01:43 AM Thread Starter
sifuentesjeeps
The weather has gotten cold since then the Jeep isn't running (when i put it in drive it wont go) the oil Gage says zero but the oil is fine. I let it warm up and it still doesn't drive but the other day I punched it and it drove. I just had the catalyst converter changed and the o 2 sensor but the engine sounds like a lawn mower. Any suggestions
SIFUENTES
sifuentesjeeps is offline
post #2 of 3 Old 12-20-2010, 04:31 AM
johnboy68
HIP2BSQR
johnboy68's Avatar
Originally Posted by sifuentesjeeps View Post
...I punched it and it drove.
Is it an automatic? If so, it could be a few things and in my experience with automatic transmissions, not a cheap fix.
..the oil Gage says zero but the oil is fine. I let it warm up and it still doesn't drive but the other day I punched it and it drove. I just had the catalyst converter changed and the o 2 sensor but the engine sounds like a lawn mower. Any suggestions
Sounds like you have the worst combination ever... problems with your transmission AND your engine. The engine "sounds like a lawn mower" and "jeep drives in reverse but doesn't in drive" are two separate problems. Also (I am assuming), the oil gage you are referring to is your oil PRESSURE gage, not an oil level gage. So, if your oil pressure is truly zero then you have BIG problems. I would suggest not running the engine until it's fixed or you will do major damage to the engine (may already have).
Without some more information, it will be hard to get an idea what the problems/solutions are.
-John-
johnboy68 is offline
post #3 of 3 Old 12-20-2010, 10:26 AM
pasinbuy
Sifu, Please fill out your profile to help us help you. If your oil pressure state zero it is important to find out why. I would look at the oil sending unit first. Make sure that you are pumping oil. Very important!
The fact that you say it sounds like a lawn mower leads me to believe that you may have a oil problem and that you may have toasted you motor. Johnboy is right on the money.
pasinbuy is offline
TJ dies when going from reverse to drive Jeep4869 TJ Wrangler Technical Forum 3 11-29-2009 04:23 PM
Need help.....jeep dies when I put it in drive but not in reverse???? philpot4811 Wrangler General Discussion 1 07-22-2009 06:19 PM
Front drive doesnt engage from transfer case! Andydunn2 YJ Wrangler Technical Forum 3 07-22-2009 06:22 AM
from drive to reverse incagoldjeep TJ Wrangler Technical Forum 7 05-05-2009 01:10 PM
90 YJ Auto won't go into drive or reverse... sgrim80 YJ Wrangler Technical Forum 2 04-27-2009 05:16 PM
