jeep doesn't turn on now - JeepForum.com
post #1 of 8 Old 04-18-2011, 11:58 AM Thread Starter
omy332
My jeep doesn't turn on. One day I was driving it on the road and it turned off on the road and didn't start. Starter works, jeep cranks up but doesn't start. I checked the fuel and fuel squirts out the fuel valve when the key is on. I checked the code flashes on the dash and it is 36 and 24. I know what 24 is throttle position sensor but I don't know what airswitch solenoid circuit is . Would bad throttle position sensor cause my jeep not to turn on. And does any one know what a code 36 airswitch solenoid circuit is and does. thanks
omy332 is offline
post #2 of 8 Old 04-18-2011, 12:02 PM
Mudmouse990
Im pretty sure the tps could cause ur jeep not to run but i think it should still start did you try giving it gas while cranking it? Also i had a problem similar to this turns out my computer was bad. The day before i jumped someone and stupid me let them hook up the cables so they hooked them up backwards and fried my computer good luck
90 yj 2.5l or pure power,thrush turbo, gutted cat, RC 4in lift,1" boom shackles, 33" BFG A/T's, outlaw alum rims,Rhino lined interior,overhead lights,connex 3300 cb, Homemade disco's, no rear trackbar
future mods- diamond plate rocker gaurds, fold down bus steps,home made front and rear bumpers , tube fenders, paint my doors red,possibly a winch, 302 ford or a 350 chevy, ford 8.8, cv style shaft and much more
Check out my build thread
My Home made Quick Disconnects Write up
Mudmouse990 is offline
post #3 of 8 Old 04-18-2011, 12:31 PM
iowajeepers
Use starter fluid to determine whether it's spark or fuel.
My bet is fuel and the pump is to blame.
Check pressure at the schrader.
When my pump started failing last week, it threw TP24 error codes.
1994 YJ, 2004 WJ, 1976 C3, 2015 Slingshot, 2001 ZX6r
iowajeepers is offline
post #4 of 8 Old 04-18-2011, 12:42 PM Thread Starter
omy332
My jeep had a new fuel pump installed about 2 to 3 years ago so i don't think its the fuel pump. And I give it gas and it still doesn't want to turn on.
omy332 is offline
post #5 of 8 Old 04-18-2011, 01:04 PM Thread Starter
omy332
ok i checked the fuel rail to check out the if the fuel pump is bad with the key in on position and at first a little gas came out but then after a second no gas came out. Does a good fuel pump suppose to squirt gas non stop through the underhood gas valve or does it squirt a little and stop.
omy332 is offline
post #6 of 8 Old 04-18-2011, 02:08 PM
Ronnie-Evans
Try shooting some starting fluid into the intake while trying to start it. If it stays running then it's fuel and most likely the pump. That's where I would start. Just because the pump is a few years old doesn't mean that's not the issue. I went through two pumps in four years. But those were bad luck I hope.
I think most of us can all agree on Jeeps, zombies, bacon, beer, and big boobies.
Ronnie-Evans is offline
post #7 of 8 Old 04-18-2011, 02:22 PM
oldtime_ironman
It's supposed to squirt non stop and strong. I know, mine did the same thing a while back. Check the fuel pump and filter.
oldtime_ironman is offline
post #8 of 8 Old 04-18-2011, 03:37 PM Thread Starter
omy332
thanks
omy332 is offline
Jeep won't turn over jeffmc TJ Wrangler Technical Forum 21 03-06-2011 06:41 PM
Jeep won't turn over... usetobejeeper TJ Wrangler Technical Forum 4 08-17-2010 01:29 AM
Jeep won't turn over admisgd YJ Wrangler Technical Forum 1 10-25-2009 12:08 AM
Jeep will not turn over Gewehr43 TJ Wrangler Technical Forum 23 03-01-2009 06:48 PM
Jeep won't turn over on first try!! mudslingertj24 TJ Wrangler Technical Forum 3 07-29-2008 08:06 AM
