Jeep dies when it wants too - JeepForum.com
post #1 of 13 Old 02-11-2014, 04:39 PM Thread Starter
ratat98
Hey all,
My 90 YJ likes to die after I've been driving and take it out of gear to come to a stop. It does it randomly, and with no warning...is it time for a nutter bypass? It also idles like a drunk donkey when it's cold....
....don't ask me how I know what a drunk donkey sounds like.....
I don't know why, but I just can't NOT own a jeep...
ratat98 is offline
post #2 of 13 Old 02-12-2014, 02:26 AM
Bigev
Possibilities are numerous, but first thing that comes to my mind is a vac. Leak.
Stethoscope and listen for a snake hissing... figured I would throw in a animal to my post as well
KCCO
Bigev is offline
post #3 of 13 Old 02-12-2014, 02:35 AM
JCashen
If you still have the carter 2bbl it is possible you need to clean the venturi tubes. My 90 uses to die pretty much anytime I came to a stop or even just idling. Nutter didn't help but a weber did.
Check your choke and make sure it functions properly.
I'm sure some of the resident experts will chime in, they will be able to help a lot more than I can l.
Think of them as the silverback gorilla of JF.
"Drippy"
90 YJ 5.2 Magnum, 4.10 LSD 8.8
JCashen is offline
post #4 of 13 Old 02-12-2014, 11:09 AM Thread Starter
ratat98
Choke is working good.. I do have the old carter and I know it needs to be gone through and cleaned. I think I'm going to do the nutter anyways and get me a weber carb eventually but I'm going to keep the carter as long as it functions. (Which may not be that much longer). I had thought about a vac leak if I do the nutter, it sounds like a vac leak won't be an issue correct?
ratat98 is offline
post #5 of 13 Old 02-12-2014, 12:39 PM Thread Starter
ratat98
Hahaha
ratat98 is offline
post #6 of 13 Old 02-12-2014, 02:13 PM
JCashen
Vacuum leak is still an issue, however with the nutter the computer won't try dumping extra fuel when it reads lean at the o2.
There are several here who still run the carter with very good results. If your stock system is intact I'd try fixing it first, if all else fails than nutter/weber/mc2100 are easy enough.
Use a can of carb cleaner to check for leaks. If it smooths out the idle whatever you sprayed is likely the culprit.
"Drippy"
JCashen is offline
post #7 of 13 Old 02-12-2014, 02:17 PM
jsawduste
2006 YJ Wrangler
Simple answer.......It`s female...........Any questions ??
jsawduste is offline
post #8 of 13 Old 02-12-2014, 06:18 PM Thread Starter
ratat98
So if the vac leak is still an issue, what vac hoses do I need to keep after the nutter besides the obvious timing, brakes, and 4wd hoses?
ratat98 is offline
post #9 of 13 Old 02-12-2014, 06:20 PM Thread Starter
ratat98
but I already have one of those in my life! I don't need another!!
ratat98 is offline
post #10 of 13 Old 02-12-2014, 06:26 PM Thread Starter
ratat98
I know..I keep posting on my own posts..
Could it be a collapsing vac line? I know a couple of the hard plastic lines were just replaced with rubber lines.
ratat98 is offline
post #11 of 13 Old 02-12-2014, 07:49 PM
Mark05059
clean the tubes... they gum up and it doesn't get fuel to idle..
1998 ZJ 5.2 Auto
1989 Wrangler Black Bone Stock 2.5l 5spd
/l , [____],
|---L--[]lllllll[]-
()_) ()_)==O=)_)
Mark05059 is offline
post #12 of 13 Old 02-17-2014, 08:28 PM Thread Starter
ratat98
OK, I've cleaned up the jeep, put a new rotor and cap on dizzy, found the ECM bad, so I did a nutter job, and, I also cleaned the carb good. Now it runs awesome, BUT, it won't start easy at all if the engine is warm.... Any ideas? I've got the timing set to 8* on the mark.
Thanks!
ratat98 is offline
post #13 of 13 Old 02-18-2014, 08:02 AM
Que89YJ
You need to adjust the timing. 8 is just where you start the timing at.
Que89YJ is offline
