Jeep cough? Im lost.. - JeepForum.com
post #1 of 6 Old 10-08-2012, 12:58 PM Thread Starter
xlTravislx
I have no idea what could be causing this problem, Ill do the best I can to explain it.
Sometimes my jeep will have a hard time keeping speed, a very hard time. This has only happened to me 2 or 3 times. Ill be driving and all of a sudden it can't keep rpms up. I have to ease off on the gas or else it will stall. Its done this after wheeling or after mid-long drives. witch means it might have to be something about tempeture, but I'm not over heating or anywhere near that. sometimes its around 2.5k rpms but other times it will be around 1.5k rpms. Generally speaking it never dose this but when it dose I can barley keep speed while driving. its almost like I have water in my engine, but I don't. There is a jeep mechanic shop i could go to but like i said, it only dose this every so often. I couldn't show him what its doing.
Could this be a vacuume leak of some sort?
do my gears need to be re oiled?
is it something electronic?
Thanks JF!
-White Jeep Club Member 231-
Replacing random parts on hunches spurred from other vehicles and peoples experiences with them is the safest bet.
xlTravislx is offline
post #2 of 6 Old 10-08-2012, 01:29 PM
NonRubicon
For starters, check for any stored codes. The check engine light may not have lit up yet because the problem hasn't occurred enough times.
One thing that comes to mind though is that the bogging could be a busted up catalytic converter. A chunk could be rattling around and randomly plugging/unplugging the exhaust.
NonRubicon is offline
post #3 of 6 Old 10-08-2012, 06:51 PM Thread Starter
xlTravislx
Alright, thanks.
I dont have any emmions laws (that im aware of), so if I wanted I could just get rid of my cat right? It dosent do anything other than control emmissions correct?
post #4 of 6 Old 10-08-2012, 07:47 PM
mrmark
have you changed your fuel filter recently? if not you may want to do it.
Wave as you pass me :D
The problems of owning 2 Jeeps ... I never know which one to work on or which YJ gets the next mod ...
mrmark is offline
post #5 of 6 Old 10-08-2012, 09:54 PM
NonRubicon
Originally Posted by xlTravislx View Post
Alright, thanks.
If you plan on driving it on the road as a street registered vehicle, Federal emissions laws require a cat. In general, having the cat will give you extra backpressure which will give you better low end torque, as well as cleaner air. It's better IMO to just get a cheap replacement (that is, don't get one from a dealership) if you find that the cat is busted up inside.
FYI - Talk of skirting Federal emissions laws regarding catalytic converters is not much tolerated here on JeepForum.
post #6 of 6 Old 10-10-2012, 09:26 AM Thread Starter
xlTravislx
Well I asked the local YJ junkies in my club and they suggested it has to be something in the ignition or fuel related. I replaced my spark plugs and wires, next is the fuel filter..
Im sure that if i were to mess with the cat conv i would just purchase a new one. i know flomaster makes an aftermarket one. like i said i was just asking.. I don't want JF to hate me
confused , jeep , problem , stall
